Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Core Assembly Removal
Ce dont vous avez besoin
    1. Core Assembly Removal, Power down your watch: étape 1, image 1 de 1
      • Before starting repairs, take your watch off the charger and power it down.
      • Remove the watch band.
      Demander à FixBot
      Ajouter un commentaire
    2. Core Assembly Removal, Unscrew the back cover: étape 2, image 1 de 1
      • Use a Tri-point Y00 screwdriver to remove the four 4.0 mm-long screws securing the back cover.
      Demander à FixBot
    3. Core Assembly Removal, Pry open the back cover: étape 3, image 1 de 2 Core Assembly Removal, Pry open the back cover: étape 3, image 2 de 2
      • Insert an opening tool into the seam between the back cover and the metal housing.
      • Twist the opening tool to create a gap.
      • Don't try to remove the back cover all the way yet. The sensor flex cable is still connected to the motherboard.
      Demander à FixBot
    4. Core Assembly Removal, Disconnect the sensor flex cable: étape 4, image 1 de 2 Core Assembly Removal, Disconnect the sensor flex cable: étape 4, image 2 de 2
      • Lay the watch face down.
      • Carefully swing open the back cover by folding it to the opposite site of the created gap.
      • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
      Demander à FixBot
    5. Core Assembly Removal, Remove the back cover: étape 5, image 1 de 1
      • Remove the back cover.
      • Make sure the rubber gasket is undamaged. If damaged, replace it with a new one during reassembly to maintain proper water resistance.
      Demander à FixBot
    1. Core Assembly Removal, Disconnect the hall sensor flex cable: étape 6, image 1 de 2 Core Assembly Removal, Disconnect the hall sensor flex cable: étape 6, image 2 de 2
      • Use the pointed end of a spudger to disconnect the hall sensor flex cable.
      Demander à FixBot
    2. Core Assembly Removal, Disconnect the display flex cable: étape 7, image 1 de 2 Core Assembly Removal, Disconnect the display flex cable: étape 7, image 2 de 2
      • Use a spudger to disconnect the display flex cable.
      Demander à FixBot
    3. Core Assembly Removal, Disconnect the side buttons: étape 8, image 1 de 2 Core Assembly Removal, Disconnect the side buttons: étape 8, image 2 de 2
      • Use a spudger to disconnect the crown button flex cable.
      Demander à FixBot
    4. Core Assembly Removal, Unscrew the motherboard: étape 9, image 1 de 1
      • Use a Phillips screwdriver to remove the 4.4 mm-long screw securing the motherboard.
      Demander à FixBot
    5. Core Assembly Removal, Remove the motherboard: étape 10, image 1 de 3 Core Assembly Removal, Remove the motherboard: étape 10, image 2 de 3 Core Assembly Removal, Remove the motherboard: étape 10, image 3 de 3
      • Use your fingers to lift the motherboard out from the watch assembly towards the bottom of the watch.
      • During reassembly, make sure none of the flex cables become trapped underneath the motherbaord.
      Demander à FixBot
    1. Core Assembly Removal, Lift the core assembly: étape 11, image 1 de 3 Core Assembly Removal, Lift the core assembly: étape 11, image 2 de 3 Core Assembly Removal, Lift the core assembly: étape 11, image 3 de 3
      • Place the corner of the flat end of a spudger in the small opening of the barometric sensor, on the opposite side of the display connector.
      • Twist and tilt the spudger to lever the core assembly out of the metal housing.
      Demander à FixBot
    2. Core Assembly Removal, Release the core assembly: étape 12, image 1 de 2 Core Assembly Removal, Release the core assembly: étape 12, image 2 de 2
      • Thread the display flex cable through the opening in the core assembly.
      Demander à FixBot
    3. Core Assembly Removal, Remove the core assembly: étape 13, image 1 de 1
      • Remove the core assembly.
      Demander à FixBot
If possible, turn on your device and test your repair before installing new adhesive and resealing.
2 autres ont terminé cette réparation.
Adriana Zwink
Membre depuis le 12/18/19
68 729 Réputation
167 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
123 membres
86 246 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 10
30 derniers jours : 47
Total : 1,614
