Aller au contenu principal
Corsair Dark Core RGB PRO SE Battery Replacement
Ce dont vous avez besoin
  1. Corsair Dark Core RGB PRO SE Battery Replacement, Battery: étape 1, image 1 de 3 Corsair Dark Core RGB PRO SE Battery Replacement, Battery: étape 1, image 2 de 3 Corsair Dark Core RGB PRO SE Battery Replacement, Battery: étape 1, image 3 de 3
    • Cover the sensor on the bottom of the mouse with your thumb so it doesn't get damaged.
    • Apply heat with a heat gun or blow dryer to the glide pad near your palm.
    • Carefully remove the glide pad with a spudger.
    • Remove the two screws from beneath the glide pad using a T5 Torx screwdriver.
  2. Corsair Dark Core RGB PRO SE Battery Replacement: étape 2, image 1 de 3 Corsair Dark Core RGB PRO SE Battery Replacement: étape 2, image 2 de 3 Corsair Dark Core RGB PRO SE Battery Replacement: étape 2, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Remove the palm rest by pulling it outwards.
    • Pull up where the latches are.
    • Take your time and work around the area to avoid snapping the plastic latches
    • Remove the top buttons by using tweezers and pushing the tabs.
  3. Corsair Dark Core RGB PRO SE Battery Replacement: étape 3, image 1 de 3 Corsair Dark Core RGB PRO SE Battery Replacement: étape 3, image 2 de 3 Corsair Dark Core RGB PRO SE Battery Replacement: étape 3, image 3 de 3
    • Remove the two screws that were underneath the left and right buttons using a Phillips #00 screwdriver.
    • Place the spudger in between the shell and the bottom of the mouse, releasing the latch.
    • Do not try to remove the top shell by pulling it up as it might break the latch.
    • Remove the six screws using a Phillips #00 screwdriver.
  4. Corsair Dark Core RGB PRO SE Battery Replacement: étape 4, image 1 de 3 Corsair Dark Core RGB PRO SE Battery Replacement: étape 4, image 2 de 3 Corsair Dark Core RGB PRO SE Battery Replacement: étape 4, image 3 de 3
    • Remove the circuit board by pushing the two latches holding it in place in opposite directions.
    • Unplug the ribbon cable by pushing the black connector holding it in place.
    • Disconnect the battery cord by pulling it up.
  5. Corsair Dark Core RGB PRO SE Battery Replacement: étape 5, image 1 de 1
    • Remove the battery with a spudger or your fingers.
4 autres ont terminé cette réparation.
Armando Sanchez Cornejo
Membre depuis le 02/09/23
469 Réputation
2 tutoriels rédigés
Équipe
2 commentaires
Where can I buy a spare battery? I don't see them in stores.
Ilya - Réponse
I found some models that are compatible on Aliexpress
carlus -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 54
30 derniers jours : 200
Total : 3,234
