Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre MP3 Player, utilisez notre manuel de réparation.
  1. Cowon iAudio 7 8GB Teardown, Cowon iAudio 7 8GB Teardown: étape 1, image 1 de 1
    • The device in original condition.
  2. Cowon iAudio 7 8GB Teardown: étape 2, image 1 de 1
    • Removed the back of the case and the PCB screws. I had to drill open one of the case screws as it was stuck.
  3. Cowon iAudio 7 8GB Teardown: étape 3, image 1 de 2 Cowon iAudio 7 8GB Teardown: étape 3, image 2 de 2
    • All parts disassembled. Second photo shows back side of the PCB.
    • As we can see, the device contains two Samsung 4GB flash chips along with a K4M28163PH-BG75 memory controller.
    • A Telechips TCC771L as main CPU.
    • A PCF50606HN battery/power management chip.
[deleted]
Membre depuis le 03/24/14
210 Réputation
1 tutoriel rédigé
3 commentaires
2011music my songs
Tong Thao - Réponse
Hi! Could you, please, say what the type of display is there?
tikhonte - Réponse
If anybody needs a new battery, try this: 3.7V polymer lithium battery 503060 or 053060
The number means the dimensions (5 x 30 x 60mm) The first number is often in 1/10mm
You’d need to solder the original cable to the battery or cables though.
Maybe you want to leave a comment here if this was helpful: adahnsplace.blogspot.com
Endre Sutus - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 14
30 derniers jours : 26
Total : 4,369
