Introduction
I've bought the device in 2017 and it has served me well for quite some time. I really liked the connectivity (USB, Line-In, Bluetooth) and the possibility to simply pop in a micro-SD card and play music anywhere without the need for a second device. All while being sturdy and quite water resistant.
However, after 3 years, the battery barely lasts for 15 minutes, so I had to replace it.
Luckily This turned out to be rather simple
Ce dont vous avez besoin
Use a flat screwdriver to carefully pry the protective mesh from the plastic case.
Carefully unplug the cable that connects the speakers to the circuit board.
Unscrew and remove the black plastic part that attaches the battery to the back of the case.
Unplug the battery from the circuit board. You might have to use a knife or some other tool to remove the glue that is on the connector.
Also very carefully remove the protective outer foam-wrapping. we will reuse it later.
Finally, take the blue cushion-wrapping and somehow try to wrap it around the battery. Then try to attach the battery to the case using the black plastic brace and the two screws.
Connect the speakers and switch the device on. If everything works, put everything back together.
Please note that your device is probably not IP66 anymore, but in my case the battery again lasts for many hours.
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
1 commentaire de tutoriel
Most accurate instructions, thanks! Nailed it too... though I might have spoiled the feng shui by using white tape on the new battery :)
