Aller au contenu principal
DR.J Professional HI-04 Lens Replacement
Ce dont vous avez besoin
  1. DR.J Professional HI-04 Lens Replacement, Lens: étape 1, image 1 de 3 DR.J Professional HI-04 Lens Replacement, Lens: étape 1, image 2 de 3 DR.J Professional HI-04 Lens Replacement, Lens: étape 1, image 3 de 3
    • Flip the projector so that the bottom is facing up.
    • Remove eight 10.0 mm screws from the back case with a Phillips #0 screwdriver.
    • The screws are set deep in the holes, so be careful not to drop them.
    • Remove two 20.0 mm screws with a Phillips #0 screwdriver.
  2. DR.J Professional HI-04 Lens Replacement: étape 2, image 1 de 3 DR.J Professional HI-04 Lens Replacement: étape 2, image 2 de 3 DR.J Professional HI-04 Lens Replacement: étape 2, image 3 de 3
    • Flip the projector so it is upright.
    • Remove the top case of the projector.
    • The shell of the projector should lift up easily but is fragile, so be gentle while lifting.
    • The top case is connected to the motherboard by cables, so avoid yanking it off to prevent snapping the connectors or damaging components.
  3. DR.J Professional HI-04 Lens Replacement: étape 3, image 1 de 2 DR.J Professional HI-04 Lens Replacement: étape 3, image 2 de 2
    • Gently lift the black flap off from the base of the lens.
  4. DR.J Professional HI-04 Lens Replacement: étape 4, image 1 de 2 DR.J Professional HI-04 Lens Replacement: étape 4, image 2 de 2
    • Remove the lens from the projector.
    • The lens is no longer secured but might still be tightly in place. Be gentle while removing it.
  5. DR.J Professional HI-04 Lens Replacement: étape 5, image 1 de 2 DR.J Professional HI-04 Lens Replacement: étape 5, image 2 de 2
    • Unscrew the cover of the lens.
Kory Lajoie
Membre depuis le 11/01/23
127 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 1-5, Petersen Fall 2023 Membre de l'équipe UMass Dartmouth, Team 1-5, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G5
4 membres
5 tutoriels rédigés
Un commentaire
how to replace lcd
Rael Sañosa - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 19
Total : 683
