Aller au contenu principal
DR.J Professional HI-04 Speaker Replacement
Ce dont vous avez besoin
  1. DR.J Professional HI-04 Speaker Replacement, Speaker: étape 1, image 1 de 3 DR.J Professional HI-04 Speaker Replacement, Speaker: étape 1, image 2 de 3 DR.J Professional HI-04 Speaker Replacement, Speaker: étape 1, image 3 de 3
    • Flip the projector so that the bottom is facing up.
    • Remove eight 10.0 mm screws from the back case with a Phillips #0 screwdriver.
    • The screws are set deep in the holes, so be careful not to drop them.
    • Remove two 20.0 mm screws with a Phillips #0 screwdriver.
  2. DR.J Professional HI-04 Speaker Replacement: étape 2, image 1 de 3 DR.J Professional HI-04 Speaker Replacement: étape 2, image 2 de 3 DR.J Professional HI-04 Speaker Replacement: étape 2, image 3 de 3
    • Flip the projector so it is upright.
    • Remove the top case of the projector.
    • The shell of the projector should lift up easily but is fragile, so be gentle while lifting.
    • The top case is connected to the motherboard by cables, so avoid yanking it off to prevent snapping the connectors or damaging components.
  3. DR.J Professional HI-04 Speaker Replacement: étape 3, image 1 de 2 DR.J Professional HI-04 Speaker Replacement: étape 3, image 2 de 2
    • Remove the three pieces of tape securing cables.
    • Keep the tape for reassembly.
  4. DR.J Professional HI-04 Speaker Replacement: étape 4, image 1 de 2 DR.J Professional HI-04 Speaker Replacement: étape 4, image 2 de 2
    • Use a Phillips #0 screwdriver to remove the four 15.0 mm screws from the motherboard.
    • Be sure to not drop the screws in the device as they can be difficult to recover.
  5. DR.J Professional HI-04 Speaker Replacement: étape 5, image 1 de 3 DR.J Professional HI-04 Speaker Replacement: étape 5, image 2 de 3 DR.J Professional HI-04 Speaker Replacement: étape 5, image 3 de 3
    • Squeeze the tab against the connector, and pull the connector straight from the socket to disconnect the speaker cable from the port.
    • The cable should come out easily so do not pull too hard.
  6. DR.J Professional HI-04 Speaker Replacement: étape 6, image 1 de 2 DR.J Professional HI-04 Speaker Replacement: étape 6, image 2 de 2
    • Use a Phillips #0 screwdriver to remove the three 15.0 mm screws from the black cover.
    • The screws are set deep in the holes, so be careful to not drop the screws, as they can be difficult to recover.
  7. DR.J Professional HI-04 Speaker Replacement: étape 7, image 1 de 2 DR.J Professional HI-04 Speaker Replacement: étape 7, image 2 de 2
    • Gently remove the black cover.
  8. DR.J Professional HI-04 Speaker Replacement: étape 8, image 1 de 2 DR.J Professional HI-04 Speaker Replacement: étape 8, image 2 de 2
    • Slide the back panel with the speaker up from the bottom case of the project.
  9. DR.J Professional HI-04 Speaker Replacement: étape 9, image 1 de 3 DR.J Professional HI-04 Speaker Replacement: étape 9, image 2 de 3 DR.J Professional HI-04 Speaker Replacement: étape 9, image 3 de 3
    • Use a Phillips #0 screwdriver to remove the two 10.0 mm screws that secure the speaker.
Baron Dutra
Membre depuis le 11/01/23
825 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-5, Petersen Fall 2023 Membre de l'équipe UMass Dartmouth, Team 1-5, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G5
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 8
Total : 130
