Aller au contenu principal
Dell Chromebook 3100 2-in-1 Input Output Board Replacement
Ce dont vous avez besoin
  1. Dell Chromebook 3100 2-in-1 Input Output Board Replacement, Back Cover: étape 1, image 1 de 2 Dell Chromebook 3100 2-in-1 Input Output Board Replacement, Back Cover: étape 1, image 2 de 2
    • Using a Phillips #1 screwdriver, remove all nine of the 5 mm screws from the back cover.
  2. Dell Chromebook 3100 2-in-1 Input Output Board Replacement: étape 2, image 1 de 2 Dell Chromebook 3100 2-in-1 Input Output Board Replacement: étape 2, image 2 de 2
    • Use the opening tool to pry the back cover off of the device.
  3. Dell Chromebook 3100 2-in-1 Input Output Board Replacement, Battery: étape 3, image 1 de 2 Dell Chromebook 3100 2-in-1 Input Output Board Replacement, Battery: étape 3, image 2 de 2
    • Disconnect the battery cable from the connector on the system board.
  4. Dell Chromebook 3100 2-in-1 Input Output Board Replacement: étape 4, image 1 de 3 Dell Chromebook 3100 2-in-1 Input Output Board Replacement: étape 4, image 2 de 3 Dell Chromebook 3100 2-in-1 Input Output Board Replacement: étape 4, image 3 de 3
    • Using a Phillips #1 screwdriver, remove the three 4 mm screws that secure the battery.
    • Remove the adhesive tape that secures the battery in place.
  5. Dell Chromebook 3100 2-in-1 Input Output Board Replacement: étape 5, image 1 de 2 Dell Chromebook 3100 2-in-1 Input Output Board Replacement: étape 5, image 2 de 2
    • Carefully remove the battery from the device.
  6. Dell Chromebook 3100 2-in-1 Input Output Board Replacement, Input/Output Board: étape 6, image 1 de 2 Dell Chromebook 3100 2-in-1 Input Output Board Replacement, Input/Output Board: étape 6, image 2 de 2
    • Remove all four 4 mm screws that secure the IO bracket and IO board using a Phillips #1 screwdriver.
  7. Dell Chromebook 3100 2-in-1 Input Output Board Replacement: étape 7, image 1 de 3 Dell Chromebook 3100 2-in-1 Input Output Board Replacement: étape 7, image 2 de 3 Dell Chromebook 3100 2-in-1 Input Output Board Replacement: étape 7, image 3 de 3
    • Flip open the retaining flaps on the two cable connectors in the IO board.
    • Disconnect the 30-pin and 40-pin IO board cables from their connectors on the motherboard.
    • Disconnect the IO cable from the system board by pulling it out of its socket.
  8. Dell Chromebook 3100 2-in-1 Input Output Board Replacement: étape 8, image 1 de 2 Dell Chromebook 3100 2-in-1 Input Output Board Replacement: étape 8, image 2 de 2
    • Slowly pull out the input/output board from the laptop.
Muhammad Ali
Membre depuis le 09/02/21
352 Réputation
2 tutoriels rédigés
Équipe
Gateway, Team 1-1, Pee Fall 2021 Membre de l'équipe Gateway, Team 1-1, Pee Fall 2021
GCC-PEE-F21S1G1
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 21
30 derniers jours : 47
Total : 952
