Aller au contenu principal
Dell Chromebook 5190 I/O board Replacement
Ce dont vous avez besoin
  1. Dell Chromebook 5190 I/O board Replacement, Battery: étape 1, image 1 de 1
    • Before starting, please make sure you have disconnected and removed all devices populating the laptop's ports.
    • Remove the nine M2.5x7.5 screws located on the bottom side of the laptop.
  2. Dell Chromebook 5190 I/O board Replacement: étape 2, image 1 de 3 Dell Chromebook 5190 I/O board Replacement: étape 2, image 2 de 3 Dell Chromebook 5190 I/O board Replacement: étape 2, image 3 de 3
    • Be cautious, the following instructions are to prevent cracking the base cover.
    • With the opening tool, pry open the upper left corner by the laptop hinge.
    • With the opening tool, pry open the upper right corner by the laptop hinge.
    • Lift off base cover.
  3. Dell Chromebook 5190 I/O board Replacement: étape 3, image 1 de 2 Dell Chromebook 5190 I/O board Replacement: étape 3, image 2 de 2
    • Unscrew and remove the M2x3 screw holding the silver metal brackets labeled "Battery Bracket" located on the top left side of the battery.
    • Unscrew and remove the M2x3 screw holding the silver metal brackets labeled "Battery Bracket" located on the top right side of the battery.
  4. Dell Chromebook 5190 I/O board Replacement: étape 4, image 1 de 2 Dell Chromebook 5190 I/O board Replacement: étape 4, image 2 de 2
    • Remove the clear adhesive tape on the system board from the battery cable from where it's seated above the battery.
    • Pull out the keyboard cable toward you to disconnect it.
  5. Dell Chromebook 5190 I/O board Replacement: étape 5, image 1 de 2 Dell Chromebook 5190 I/O board Replacement: étape 5, image 2 de 2
    • Remove the black adhesive tape on the system board from the battery cable.
    • Dismount the cable from where it's seated above the battery.
  6. Dell Chromebook 5190 I/O board Replacement: étape 6, image 1 de 3 Dell Chromebook 5190 I/O board Replacement: étape 6, image 2 de 3 Dell Chromebook 5190 I/O board Replacement: étape 6, image 3 de 3
    • Unscrew and remove the four M2x3 screws on each corner of the battery.
    • Dismount the battery.
  7. Dell Chromebook 5190 I/O board Replacement, I/O board: étape 7, image 1 de 2 Dell Chromebook 5190 I/O board Replacement, I/O board: étape 7, image 2 de 2
    • Disconnect the first purple I/O cable by lifting upwards and pulling away from the I/O connector.
  8. Dell Chromebook 5190 I/O board Replacement: étape 8, image 1 de 2 Dell Chromebook 5190 I/O board Replacement: étape 8, image 2 de 2
    • Disconnect the second purple I/O cable by lifting upwards and pulling away from the I/O connector.
  9. Dell Chromebook 5190 I/O board Replacement: étape 9, image 1 de 3 Dell Chromebook 5190 I/O board Replacement: étape 9, image 2 de 3 Dell Chromebook 5190 I/O board Replacement: étape 9, image 3 de 3
    • Unscrew the two (M2x4) screws on the I/O bracket.
    • Lift off the I/O bracket.
  10. Dell Chromebook 5190 I/O board Replacement: étape 10, image 1 de 2 Dell Chromebook 5190 I/O board Replacement: étape 10, image 2 de 2
    • Unscrew the three (M2x4) screws on the I/O board.
    • Dismount the I/O board.
Denise Cano
Membre depuis le 02/10/22
617 Réputation
4 tutoriels rédigés
Équipe
Gateway, Team 1-3, Pee Spring 2022 Membre de l'équipe Gateway, Team 1-3, Pee Spring 2022
GCC-PEE-S22S1G3
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 4
Total : 186
