Aller au contenu principal
Dell Inspiron 11 i3147 Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 11 i3147 Hard Drive Replacement, Hard Drive: étape 1, image 1 de 1
    • Close the computer and turn it over, with the bottom of the computer facing up.
  2. Dell Inspiron 11 i3147 Hard Drive Replacement: étape 2, image 1 de 1
    • Remove the nine 7.6mm PH0 screws on the cover.
  3. Dell Inspiron 11 i3147 Hard Drive Replacement: étape 3, image 1 de 1
    • Use a plastic opening tool to remove the cover from the computer.
  4. Dell Inspiron 11 i3147 Hard Drive Replacement: étape 4, image 1 de 1
    • Remove the three 4.7mm PH0 screws that secure the battery to the computer.
  5. Dell Inspiron 11 i3147 Hard Drive Replacement: étape 5, image 1 de 1
    • Remove the hard drive cable from the battery.
  6. Dell Inspiron 11 i3147 Hard Drive Replacement: étape 6, image 1 de 1
    • Lift the battery from the computer.
  7. Dell Inspiron 11 i3147 Hard Drive Replacement: étape 7, image 1 de 1
    • Peel off the adhesive strap from the hard drive.
  8. Dell Inspiron 11 i3147 Hard Drive Replacement: étape 8, image 1 de 1
    • Use a PH0 screwdriver to remove the 2 3.9 mm PH0 screws on the hard drive.
  9. Dell Inspiron 11 i3147 Hard Drive Replacement: étape 9, image 1 de 1
    • Lift the hard drive to free it from the laptop.
  10. Dell Inspiron 11 i3147 Hard Drive Replacement: étape 10, image 1 de 1
    • Remove interposer from the hard drive.
  11. Dell Inspiron 11 i3147 Hard Drive Replacement: étape 11, image 1 de 1
    • Use pull tab to remove hard drive cable from motherboard.
Muhammad Erchid
Membre depuis le 10/09/18
1 087 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S1-G6, Leahy Fall 2018 Membre de l'équipe USF Tampa, Team S1-G6, Leahy Fall 2018
USFT-LEAHY-F18S1G6
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 11
30 derniers jours : 12
Total : 304
