Aller au contenu principal
Dell Inspiron 11-3162 LCD Screen Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 11-3162 LCD Screen Replacement, Back Cover Removal: étape 1, image 1 de 2 Dell Inspiron 11-3162 LCD Screen Replacement, Back Cover Removal: étape 1, image 2 de 2
    Outil utilisé dans cette étape :
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use tweezers to pry and remove the center screw cover on the back cover.
  2. Dell Inspiron 11-3162 LCD Screen Replacement: étape 2, image 1 de 2 Dell Inspiron 11-3162 LCD Screen Replacement: étape 2, image 2 de 2
    • Use a Phillips screwdriver to unscrew the nine 6.8 mm screws securing the back cover.
  3. Dell Inspiron 11-3162 LCD Screen Replacement: étape 3, image 1 de 1
    • Use a spudger to pry around the base edges of the back cover to loosen it from the laptop.
    • Do not fully remove the cover, as it is still attached to the laptop with cables.
  4. Dell Inspiron 11-3162 LCD Screen Replacement: étape 4, image 1 de 3 Dell Inspiron 11-3162 LCD Screen Replacement: étape 4, image 2 de 3 Dell Inspiron 11-3162 LCD Screen Replacement: étape 4, image 3 de 3
    • If you are only replacing the battery, you can skip this step. Be careful not to strain the still-connected cable as you work.
    • Unlock the wide ZIF connector securing the flex cable.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap.
    • Pull the ribbon cable outwards to disconnect the back cover from the motherboard.
  5. Dell Inspiron 11-3162 LCD Screen Replacement, Battery: étape 5, image 1 de 2 Dell Inspiron 11-3162 LCD Screen Replacement, Battery: étape 5, image 2 de 2
    • Use a Phillips screwdriver to unscrew the three 4 mm screws securing the battery.
  6. Dell Inspiron 11-3162 LCD Screen Replacement: étape 6, image 1 de 3 Dell Inspiron 11-3162 LCD Screen Replacement: étape 6, image 2 de 3 Dell Inspiron 11-3162 LCD Screen Replacement: étape 6, image 3 de 3
    • Use your fingers (or a set of tweezers) to disconnect the battery cable from the motherboard by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
    • Lift and remove the battery from its recess.
  7. Dell Inspiron 11-3162 LCD Screen Replacement, Wireless WLAN Card: étape 7, image 1 de 2 Dell Inspiron 11-3162 LCD Screen Replacement, Wireless WLAN Card: étape 7, image 2 de 2
    • Use the phillips screwdriver with the PH000 head to unscrew the 3.8mm screw.
  8. Dell Inspiron 11-3162 LCD Screen Replacement: étape 8, image 1 de 2 Dell Inspiron 11-3162 LCD Screen Replacement: étape 8, image 2 de 2
    • Using the tweezers, pull the white and black wires off of the WiFi Chip.
  9. Dell Inspiron 11-3162 LCD Screen Replacement: étape 9, image 1 de 1
    • Pull out the WiFi Chip.
  10. Dell Inspiron 11-3162 LCD Screen Replacement, LCD Screen: étape 10, image 1 de 2 Dell Inspiron 11-3162 LCD Screen Replacement, LCD Screen: étape 10, image 2 de 2
    • Remove the two screws that hold down the LCD hinges.
  11. Dell Inspiron 11-3162 LCD Screen Replacement: étape 11, image 1 de 1
    • Pull the hinges back and remove the screen.
  12. Dell Inspiron 11-3162 LCD Screen Replacement: étape 12, image 1 de 2 Dell Inspiron 11-3162 LCD Screen Replacement: étape 12, image 2 de 2
    • Remove the hinge covers with your spudger tool.
  13. Dell Inspiron 11-3162 LCD Screen Replacement: étape 13, image 1 de 2 Dell Inspiron 11-3162 LCD Screen Replacement: étape 13, image 2 de 2
    • Carefully remove the LCD Bezel with your regular black nylon spudger tool by bringing it all the way around the outer edges of your screen.
  14. Dell Inspiron 11-3162 LCD Screen Replacement: étape 14, image 1 de 3 Dell Inspiron 11-3162 LCD Screen Replacement: étape 14, image 2 de 3 Dell Inspiron 11-3162 LCD Screen Replacement: étape 14, image 3 de 3
    • Remove the four screws with a PH00 sized bit.
    • Flip the screen over.
  15. Dell Inspiron 11-3162 LCD Screen Replacement: étape 15, image 1 de 1
    • Loosen the tape, and remove the LCD Cable.
    • Remove the screen.
5 autres ont terminé cette réparation.
Jared Johnson
Membre depuis le 09/29/16
589 Réputation
2 tutoriels rédigés
Équipe
2 commentaires de tutoriel
Between steps 9 and 10, the motherboard is removed and no description photos are provided for this. I undid the cable on the right hinge and then removed the hinges and screen with the motherboard in place, but the pictures definitely show it removed. Otherwise a very easy to follow process.
Philip Blakemore - Réponse
I agree with Philip’s comment re: the missing step between 9 and 10. I successfully followed these very clear instructions to repair my daughter’s Chromebook. Thank you!
Katrina Dalrymple - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 21
Total : 1,841
