Aller au contenu principal
Dell Inspiron 11-3162 Wireless WLAN Card Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 11-3162 Wireless WLAN Card Replacement, Back Cover Removal: étape 1, image 1 de 2 Dell Inspiron 11-3162 Wireless WLAN Card Replacement, Back Cover Removal: étape 1, image 2 de 2
    Outil utilisé dans cette étape :
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use tweezers to pry and remove the center screw cover on the back cover.
  2. Dell Inspiron 11-3162 Wireless WLAN Card Replacement: étape 2, image 1 de 2 Dell Inspiron 11-3162 Wireless WLAN Card Replacement: étape 2, image 2 de 2
    • Use a Phillips screwdriver to unscrew the nine 6.8 mm screws securing the back cover.
  3. Dell Inspiron 11-3162 Wireless WLAN Card Replacement: étape 3, image 1 de 1
    • Use a spudger to pry around the base edges of the back cover to loosen it from the laptop.
    • Do not fully remove the cover, as it is still attached to the laptop with cables.
  4. Dell Inspiron 11-3162 Wireless WLAN Card Replacement: étape 4, image 1 de 3 Dell Inspiron 11-3162 Wireless WLAN Card Replacement: étape 4, image 2 de 3 Dell Inspiron 11-3162 Wireless WLAN Card Replacement: étape 4, image 3 de 3
    • If you are only replacing the battery, you can skip this step. Be careful not to strain the still-connected cable as you work.
    • Unlock the wide ZIF connector securing the flex cable.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap.
    • Pull the ribbon cable outwards to disconnect the back cover from the motherboard.
  5. Dell Inspiron 11-3162 Wireless WLAN Card Replacement, Battery: étape 5, image 1 de 2 Dell Inspiron 11-3162 Wireless WLAN Card Replacement, Battery: étape 5, image 2 de 2
    • Use a Phillips screwdriver to unscrew the three 4 mm screws securing the battery.
  6. Dell Inspiron 11-3162 Wireless WLAN Card Replacement: étape 6, image 1 de 3 Dell Inspiron 11-3162 Wireless WLAN Card Replacement: étape 6, image 2 de 3 Dell Inspiron 11-3162 Wireless WLAN Card Replacement: étape 6, image 3 de 3
    • Use your fingers (or a set of tweezers) to disconnect the battery cable from the motherboard by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
    • Lift and remove the battery from its recess.
  7. Dell Inspiron 11-3162 Wireless WLAN Card Replacement, Wireless WLAN Card: étape 7, image 1 de 2 Dell Inspiron 11-3162 Wireless WLAN Card Replacement, Wireless WLAN Card: étape 7, image 2 de 2
    • Use the phillips screwdriver with the PH000 head to unscrew the 3.8mm screw.
  8. Dell Inspiron 11-3162 Wireless WLAN Card Replacement: étape 8, image 1 de 2 Dell Inspiron 11-3162 Wireless WLAN Card Replacement: étape 8, image 2 de 2
    • Using the tweezers, pull the white and black wires off of the WiFi Chip.
  9. Dell Inspiron 11-3162 Wireless WLAN Card Replacement: étape 9, image 1 de 1
    • Pull out the WiFi Chip.
4 autres ont terminé cette réparation.
Dominic DeLong
Membre depuis le 09/29/16
775 Réputation
4 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 10
30 derniers jours : 11
Total : 703
