Aller au contenu principal
Dell Inspiron 13 7378 Heat Sink Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 13 7378 Heat Sink Replacement, Back Cover: étape 1, image 1 de 1
    • Set the laptop with its underside facing up for improved accessibility.
  2. Dell Inspiron 13 7378 Heat Sink Replacement: étape 2, image 1 de 2 Dell Inspiron 13 7378 Heat Sink Replacement: étape 2, image 2 de 2
    • Using a Phillips #00 screwdriver, extract the nine 3 mm screws located on the back of the laptop.
  3. Dell Inspiron 13 7378 Heat Sink Replacement: étape 3, image 1 de 3 Dell Inspiron 13 7378 Heat Sink Replacement: étape 3, image 2 de 3 Dell Inspiron 13 7378 Heat Sink Replacement: étape 3, image 3 de 3
    • Carefully pry open the back of the back of the laptop using opening picks.
    • Carefully raise and detach the back cover from the laptop.
    • Exercise caution to prevent damaging or cracking the device's back cover.
  4. Dell Inspiron 13 7378 Heat Sink Replacement, Heat Sink: étape 4, image 1 de 1
    • Carefully remove the four screws securing the heat sink by using a Phillips screwdriver.
  5. Dell Inspiron 13 7378 Heat Sink Replacement: étape 5, image 1 de 2 Dell Inspiron 13 7378 Heat Sink Replacement: étape 5, image 2 de 2
    • Check to see if the fan will obstruct the removal process and if so, remove the fan first before removing the heat sink to prevent any damage.
    • In the absence of any obstacles impeding the removal process, gently lift and extract the heat sink from its position.
  6. Dell Inspiron 13 7378 Heat Sink Replacement: étape 6, image 1 de 1
    • Before you install a new compatible cooling system, place a fresh coat of thermal paste in the center of where the previous cooling system used to be.
Replace the back cover to complete the process.
3 autres ont terminé cette réparation.
Javier Perez
Membre depuis le 02/08/22
277 Réputation
2 tutoriels rédigés
Équipe
Gateway, Team 1-3, Saknee Spring 2022 Membre de l'équipe Gateway, Team 1-3, Saknee Spring 2022
GCC-SAKNEE-S22S1G3
5 membres
16 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 15
30 derniers jours : 19
Total : 372
