Introduction
This is a guide for removal and replacement of the Display Assembly for the Dell Inspiron 17-7347 laptop.
Ce dont vous avez besoin
Flip the device over, so that the back is facing up.
Using a Phillips screwdriver, remove the 10 2.5mm x 8mm screws
Use the suction cup to lift off the back case.
You should be able to identify the fan.
This is the 2mm x 2mm JIS #00 screw.
This is the 2mm x 3mm JIS #00 screw.
Using a Phillips #0 screwdriver, loosen and remove the two 3.0 mm hard drive screws.
Lift the hard drive up and out of the device.
Using a Phillips #0 screwdriver, loosen the three 3.0 mm heat sink screws.
Remove the Heat Sink.
