Aller au contenu principal
Dell Inspiron 14 5100 Battery Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 14 5100 Battery Replacement, Dell Inspiron 14 5100 Disassembly: étape 1, image 1 de 3 Dell Inspiron 14 5100 Battery Replacement, Dell Inspiron 14 5100 Disassembly: étape 1, image 2 de 3 Dell Inspiron 14 5100 Battery Replacement, Dell Inspiron 14 5100 Disassembly: étape 1, image 3 de 3
    • Make sure to disconnect the power source to the device.
    • Remove nine screws securing the base cover of the laptop's keyboard assembly using the Phillips #0 screwdriver.
    • There are 2 sets of screws.
    • Remove the 3 captive screws.
    • Remove the 6M2*6 screws.
  2. Dell Inspiron 14 5100 Battery Replacement: étape 2, image 1 de 2 Dell Inspiron 14 5100 Battery Replacement: étape 2, image 2 de 2
    • Pry open the laptop to separate the base cover from the keyboard assembly.
    • You may use your fingertips or use plastic opening tools.
  3. Dell Inspiron 14 5100 Battery Replacement, Battery: étape 3, image 1 de 2 Dell Inspiron 14 5100 Battery Replacement, Battery: étape 3, image 2 de 2
    • Remove the four Phillips #0 screws securing the battery to the keyboard assembly.
  4. Dell Inspiron 14 5100 Battery Replacement: étape 4, image 1 de 3 Dell Inspiron 14 5100 Battery Replacement: étape 4, image 2 de 3 Dell Inspiron 14 5100 Battery Replacement: étape 4, image 3 de 3
    • Peel off the tape securing the battery cable to the battery cable connector.
    • Disconnect and remove the old battery.
2 autres ont terminé cette réparation.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 28
30 derniers jours : 70
Total : 4,464
