Aller au contenu principal
Dell Inspiron 14 5405 RAM Upgrade
Ce dont vous avez besoin
  1. Dell Inspiron 14 5405 RAM Upgrade, RAM Upgrade: étape 1, image 1 de 2 Dell Inspiron 14 5405 RAM Upgrade, RAM Upgrade: étape 1, image 2 de 2
    • Using a Philipps head screw driver remove all screws marked with a green ring.
    • Also loosen the ones with an orange ring as far as possible. (They are the two screws closest to the hinges of the screen) Since these are retaining screws, they should not come out completely
    • If one (or both) do come out, that's no big deal. Just make sure to find and remove the metallic ring that was supposed to hold them in.
  2. Dell Inspiron 14 5405 RAM Upgrade: étape 2, image 1 de 1
    • Using a plastic prying tool (or guitar pick) go around the fringe of the device to open the plastic clips holding it together.
    • It is easiest if you start at the display hinge next to one of the retaining screws.
    • If you've never opened these kinds of clips before, you may need a bit more force than you're comfortable with.
  3. Dell Inspiron 14 5405 RAM Upgrade: étape 3, image 1 de 1
    • Carefully lift up the back cover of the laptop.
    • You will need a bit of force to unclip this plastic thing that attaches to the back of the device. (Marked with an arrow in the picture.)
  4. Dell Inspiron 14 5405 RAM Upgrade: étape 4, image 1 de 2 Dell Inspiron 14 5405 RAM Upgrade: étape 4, image 2 de 2
    • Once you're in the machine, lift up the outer part of this rubber covering to reveal the unoccupied RAM slot.
    • Now put in your ram.
    • It is only possible to seat it in the correct orientation because of a small non-symmetrical indentation in both the slot and the ram.
    • You may need to bend these little metal arms out a bit to get the ram to fit in.
    • Dell has also provided a small instruction using pictographs on the rubber covering.
    • When the RAM is properly seated, you will hear it "click" into place.
  5. Dell Inspiron 14 5405 RAM Upgrade: étape 5, image 1 de 1
    • Put the back cover back on but don't yet close the plastic clips or screw in the screws.
    • Firstly, boot up the computer while hitting F2 to open the BIOS configuration.
    • Check if the detected memory matches with what you have installed.
    • If it doesn't, you may have to take out the ram and put it back in again, making sure it really is all the way in.
    • Turn off the computer by hitting the power key.
    • Finally, push against the plastic clips to close them again.
    • Tighten both of the retaining screws. (Or put them back in if they came out)
    • Put the remaining screws back in.
    Can I just note that this was super helpful for a Dell Inspirion 14 5425. It seemed close enough and it is.
    Steven R. Loomis - Réponse
Luckily there still are some companies out there, that still make devices with user serviceable ram.
Adding in new RAM is pretty easy and the fact that they even include pictographs of how to seat the ram correctly inside the device is a nice bonus.
2 autres ont terminé cette réparation.
Jennifer Kirsch
Membre depuis le 03/27/21
229 Réputation
1 tutoriel rédigé
Un commentaire
what product do you suggest for installation? I need 4 gigs of video memory to run Forza Horizon 5. Thanks
Jack T - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 17
Total : 2,265
