Aller au contenu principal
Dell Inspiron 15 5584 DC Jack Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15 5584 DC Jack Replacement, Bottom Cover: étape 1, image 1 de 1
    • Make sure to turn off and unplug your laptop before starting.
    • Turn over the laptop so that the bottom is facing upwards, and the Inspiron logo is upside-down.
  2. Dell Inspiron 15 5584 DC Jack Replacement: étape 2, image 1 de 3 Dell Inspiron 15 5584 DC Jack Replacement: étape 2, image 2 de 3 Dell Inspiron 15 5584 DC Jack Replacement: étape 2, image 3 de 3
    • Remove the seven 7 mm screws from the bottom using a Phillips #0 screwdriver.
    • Loosen the two captive back corner screws using a Phillips #0 screwdriver.
    • The two corner screws are not removable. A clicking sounds indicates that the screw is fully loosened.
  3. Dell Inspiron 15 5584 DC Jack Replacement: étape 3, image 1 de 2 Dell Inspiron 15 5584 DC Jack Replacement: étape 3, image 2 de 2
    • Slide an iFixit opening tool underneath the right side USB port and the keyboard.
    • Gently trace the iFixit opening tool along the entire outer rim of the laptop, carefully applying an upwards pressure.
    • Be careful not to force open the plate or push too much off without loosening the other sides. This can cause the bottom cover to crack.
  4. Dell Inspiron 15 5584 DC Jack Replacement: étape 4, image 1 de 2 Dell Inspiron 15 5584 DC Jack Replacement: étape 4, image 2 de 2
    • Gently pry off the bottom cover from the laptop.
    • Use the iFixit opening tool to loosen any spots you may have missed from Step 3.
  5. Dell Inspiron 15 5584 DC Jack Replacement, Battery: étape 5, image 1 de 2 Dell Inspiron 15 5584 DC Jack Replacement, Battery: étape 5, image 2 de 2
    • Remove the four 3.5 mm screws holding the battery down with a JIS #0 screwdriver.
  6. Dell Inspiron 15 5584 DC Jack Replacement: étape 6, image 1 de 3 Dell Inspiron 15 5584 DC Jack Replacement: étape 6, image 2 de 3 Dell Inspiron 15 5584 DC Jack Replacement: étape 6, image 3 de 3
    • Detach the motherboard connector tab from the top left of the battery.
    • Remove the battery from the device.
    • Be sure to carefully wiggle the connector out from the battery socket. Ripping it out too forcefully could damage the socket.
  7. Dell Inspiron 15 5584 DC Jack Replacement, DC Jack: étape 7, image 1 de 2 Dell Inspiron 15 5584 DC Jack Replacement, DC Jack: étape 7, image 2 de 2
    • Remove the three 6 mm screws holding down the screen hinge in the upper right corner using a JIS #0 screwdriver.
  8. Dell Inspiron 15 5584 DC Jack Replacement: étape 8, image 1 de 2 Dell Inspiron 15 5584 DC Jack Replacement: étape 8, image 2 de 2
    • Grasp the screen hinge and lift it up.
  9. Dell Inspiron 15 5584 DC Jack Replacement: étape 9, image 1 de 3 Dell Inspiron 15 5584 DC Jack Replacement: étape 9, image 2 de 3 Dell Inspiron 15 5584 DC Jack Replacement: étape 9, image 3 de 3
    Outil utilisé dans cette étape :
    • Lift up the sticker covering the DC jack connector using tweezers.
    • Using tweezers, detach the motherboard connector and lift the jack out of place.
    • Remove the DC jack from the laptop.
Sam Vorn
Membre depuis le 03/29/22
977 Réputation
9 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-1, Mellen Spring 2022 Membre de l'équipe UMass Dartmouth, Team 1-1, Mellen Spring 2022
UMASSD-MELLEN-S22S1G1
3 membres
10 tutoriels rédigés
Un commentaire
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 10
30 derniers jours : 37
Total : 1,124
