Aller au contenu principal
Dell Inspiron 15 7579 Fan Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15 7579 Fan Replacement, Back Panel: étape 1, image 1 de 1
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 Fan Replacement: étape 2, image 1 de 2 Dell Inspiron 15 7579 Fan Replacement: étape 2, image 2 de 2
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Dell Inspiron 15 7579 Fan Replacement, Fan: étape 3, image 1 de 2 Dell Inspiron 15 7579 Fan Replacement, Fan: étape 3, image 2 de 2
    • Remove the two 7.9 mm screws from the fan with a Phillips #0 screwdriver.
  4. Dell Inspiron 15 7579 Fan Replacement: étape 4, image 1 de 2 Dell Inspiron 15 7579 Fan Replacement: étape 4, image 2 de 2
    • Unplug the wires from the port.
    • Be sure to pull from the plastic connector, not the wires.
  5. Dell Inspiron 15 7579 Fan Replacement: étape 5, image 1 de 1
    • Carefully lift the fan out of the computer.
Richard Parker
Membre depuis le 09/20/21
97 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 11
Total : 225
