Aller au contenu principal
Dell Inspiron 15 7579 Speakers Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15 7579 Speakers Replacement, Back Panel: étape 1, image 1 de 1
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 Speakers Replacement: étape 2, image 1 de 2 Dell Inspiron 15 7579 Speakers Replacement: étape 2, image 2 de 2
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Dell Inspiron 15 7579 Speakers Replacement, Battery: étape 3, image 1 de 2 Dell Inspiron 15 7579 Speakers Replacement, Battery: étape 3, image 2 de 2
    • Remove the two 7.8 mm long screws on the left side of the battery with the Phillips #1 screwdriver.
  4. Dell Inspiron 15 7579 Speakers Replacement: étape 4, image 1 de 1
    • Pull out the fabric clip that attaches the battery to the main board from the connector by hand.
    • Remove the battery from the device.
  5. Dell Inspiron 15 7579 Speakers Replacement, Speakers: étape 5, image 1 de 2 Dell Inspiron 15 7579 Speakers Replacement, Speakers: étape 5, image 2 de 2
    Outil utilisé dans cette étape :
    • After battery is removed, locate the left and right speakers.
    • On the right speaker assembly, remove the pin connector using the tweezers.
  6. Dell Inspiron 15 7579 Speakers Replacement: étape 6, image 1 de 2 Dell Inspiron 15 7579 Speakers Replacement: étape 6, image 2 de 2
    • Use the metal spudger to pry off the right speaker assembly.
  7. Dell Inspiron 15 7579 Speakers Replacement: étape 7, image 1 de 1
    • Use a metal spudger to pry off left speaker assembly.
  8. Dell Inspiron 15 7579 Speakers Replacement: étape 8, image 1 de 2 Dell Inspiron 15 7579 Speakers Replacement: étape 8, image 2 de 2
    • Un-thread the wire by removing them from under the plastic clamps. No tools are required for this step. Repeat for both sides.
  9. Dell Inspiron 15 7579 Speakers Replacement: étape 9, image 1 de 2 Dell Inspiron 15 7579 Speakers Replacement: étape 9, image 2 de 2
    • Pull the adhesive cable away from the metal backing and push the right speaker assembly under it.
    • Remove the Velcro holding the speaker wire and remove the speakers from the device.
Inaki Madrigal
Membre depuis le 04/23/18
775 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team S24-G9, Maness Spring 2018 Membre de l'équipe Cal Poly, Team S24-G9, Maness Spring 2018
CPSU-MANESS-S18S24G9
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 13
30 derniers jours : 22
Total : 1,292
