Aller au contenu principal
Dell Inspiron 15-5567 Wireless Card Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15-5567 Wireless Card Replacement, Back Cover: étape 1, image 1 de 3 Dell Inspiron 15-5567 Wireless Card Replacement, Back Cover: étape 1, image 2 de 3 Dell Inspiron 15-5567 Wireless Card Replacement, Back Cover: étape 1, image 3 de 3
    • Orient the laptop with the back cover facing upward and the INSPIRON engraving reads legible (not flipped).
    • Remove 13 M2.5x8mm screws using a Philips #0 screwdriver.
    • Remove two M2x4mm screws using the same screwdriver.
  2. Dell Inspiron 15-5567 Wireless Card Replacement: étape 2, image 1 de 2 Dell Inspiron 15-5567 Wireless Card Replacement: étape 2, image 2 de 2
    • Insert the blue plastic opening tool into the crease of the CD driver, and pop it open.
    • Slide the rest of it out with your hand.
  3. Dell Inspiron 15-5567 Wireless Card Replacement: étape 3, image 1 de 3 Dell Inspiron 15-5567 Wireless Card Replacement: étape 3, image 2 de 3 Dell Inspiron 15-5567 Wireless Card Replacement: étape 3, image 3 de 3
    • Remove three M2x2mm screws underneath the CD driver with the same Philips #0 screwdriver.
    • Place the blue plastic opening tool in the crease of the cover and push it upward to open the back cover.
    • Grab the corners of the cover firmly and lift it up.
    • Some parts are weaker than others; open it gently from corners.
  4. Dell Inspiron 15-5567 Wireless Card Replacement, Wireless Card: étape 4, image 1 de 3 Dell Inspiron 15-5567 Wireless Card Replacement, Wireless Card: étape 4, image 2 de 3 Dell Inspiron 15-5567 Wireless Card Replacement, Wireless Card: étape 4, image 3 de 3
    • Remove one M2x3mm screw from the bracket holding the card using a Phillips #0 screwdriver.
    • Lift and remove the bracket with your hand.
  5. Dell Inspiron 15-5567 Wireless Card Replacement: étape 5, image 1 de 3 Dell Inspiron 15-5567 Wireless Card Replacement: étape 5, image 2 de 3 Dell Inspiron 15-5567 Wireless Card Replacement: étape 5, image 3 de 3
    • Disconnect the antennae cables connected to the card using the opening tool.
    • Slide the wireless card off of its socket and lift it with your hand and remove it.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 12
30 derniers jours : 29
Total : 1,373
