Aller au contenu principal
Dell Inspiron 15-7548 Display Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15-7548 Display Replacement, Remove case screws: étape 1, image 1 de 2 Dell Inspiron 15-7548 Display Replacement, Remove case screws: étape 1, image 2 de 2
    • Loosen the four 2x3mm captive screws (yellow) on the bottom of the shell. These screws will not come out.
    • Unscrew the six 2.5x6mm (blue) screws and remove them using a Phillips #1 screwdriver. The center screw is magnetized and will drop out when the laptop is turned upside down. It can be difficult to get out otherwise.
  2. Dell Inspiron 15-7548 Display Replacement, Remove shell: étape 2, image 1 de 3 Dell Inspiron 15-7548 Display Replacement, Remove shell: étape 2, image 2 de 3 Dell Inspiron 15-7548 Display Replacement, Remove shell: étape 2, image 3 de 3
    • Remove the clamshell from the top down using a smudging tool. The shell should come off fairly easily without much resistance.
  3. Dell Inspiron 15-7548 Display Replacement, Disconnect Battery: étape 3, image 1 de 2 Dell Inspiron 15-7548 Display Replacement, Disconnect Battery: étape 3, image 2 de 2
    • Disconnect the Battery from the mainboard to ensure power is not running through the board during the repair.
  4. Dell Inspiron 15-7548 Display Replacement, Remove LCD Bezel: étape 4, image 1 de 3 Dell Inspiron 15-7548 Display Replacement, Remove LCD Bezel: étape 4, image 2 de 3 Dell Inspiron 15-7548 Display Replacement, Remove LCD Bezel: étape 4, image 3 de 3
    • Using two plastic removal tools or a spudger, gently work around the LCD bezel until it is free from the LCD case. Apply heat as necessary, however, use caution as heat can warp the bezel.
  5. Dell Inspiron 15-7548 Display Replacement, Remove bracket cover: étape 5, image 1 de 2 Dell Inspiron 15-7548 Display Replacement, Remove bracket cover: étape 5, image 2 de 2
    • Remove the plastic bracket that sits between the LCD and the keyboard.
  6. Dell Inspiron 15-7548 Display Replacement, Remove old adhesive from LCD bezel: étape 6, image 1 de 1
    • Clean off all old adhesive from the LCD bezel. Roll the adhesive into a ball and discard.
  7. Dell Inspiron 15-7548 Display Replacement, Remove LCD Panel: étape 7, image 1 de 3 Dell Inspiron 15-7548 Display Replacement, Remove LCD Panel: étape 7, image 2 de 3 Dell Inspiron 15-7548 Display Replacement, Remove LCD Panel: étape 7, image 3 de 3
    • Remove the 6 screws which hold the LCD to the mount.
    • Use a spudge tool to check the amount of tension between the LCD and the mount. If the LCD comes away from the mount easily, remove gently, lower from the top down (pull towards you) and rest it on the keyboard.
    • If the LCD shows signs of tension, do not force it off of the frame. Use either a heat gun or dehydrator (preferable) to loosen the adhesive behind the panel.
    • If placing in a dehydrator, leave the laptop (WITHOUT BATTERY) for 30 minutes at high heat.
    • When removing from the dehydrator (if required) move quickly to remove the LCD from the frame. The heat will dissipate quickly,
  8. Dell Inspiron 15-7548 Display Replacement, Disconnect LCD cable: étape 8, image 1 de 2 Dell Inspiron 15-7548 Display Replacement, Disconnect LCD cable: étape 8, image 2 de 2
    • Once the LCD is removed from the frame and has been set on the keyboard, peel back the black adhesive, which will reveal the LCD connector.
    • Flip the silver tab (blue arrow) and disconnect the cable (Orange Circle) from the old LCD.
    • Once removed, discard the old LCD and prepare the new LCD for installation. (remove from wrap, etc)
  9. Dell Inspiron 15-7548 Display Replacement, Install new LCD: étape 9, image 1 de 3 Dell Inspiron 15-7548 Display Replacement, Install new LCD: étape 9, image 2 de 3 Dell Inspiron 15-7548 Display Replacement, Install new LCD: étape 9, image 3 de 3
    • Reconnect the LCD cable to the LCD panel and secure the silver tab in place
    • Position the new LCD panel over the six screw slots
    • Secure the new LCD to the frame using the six corresponding screws
  10. Dell Inspiron 15-7548 Display Replacement, Reassemble: étape 10, image 1 de 3 Dell Inspiron 15-7548 Display Replacement, Reassemble: étape 10, image 2 de 3 Dell Inspiron 15-7548 Display Replacement, Reassemble: étape 10, image 3 de 3
    • Apply new adhesives to the LCD bezel
    • Snap the LCD bezel back in place over the new LCD starting from bottom to top
    • Snap the cover between the LCD and keyboard back in place
Phillip Johnson
Membre depuis le 07/29/19
181 Réputation
1 tutoriel rédigé
Un commentaire
What kind of “adhesive” would I need to glue the display back into the cover?
Horst Walter - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 12
Total : 2,751
