Aller au contenu principal
Dell Inspiron 15-7559 Battery Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15-7559 Battery Replacement, Back Panel: étape 1, image 1 de 1
    • Turn off the computer.
    • Disconnect the charging cable from the computer.
    • Failure to turn off the device and disconnect the cable could lead to personal injury or device damage.
    • Flip the computer upside down.
  2. Dell Inspiron 15-7559 Battery Replacement: étape 2, image 1 de 3 Dell Inspiron 15-7559 Battery Replacement: étape 2, image 2 de 3 Dell Inspiron 15-7559 Battery Replacement: étape 2, image 3 de 3
    • Remove the captive screw located on the top section of the back panel, using a Philips #1 screwdriver.
    • Keep in mind that the screw cannot be fully removed from the panel, even when fully loosened.
  3. Dell Inspiron 15-7559 Battery Replacement: étape 3, image 1 de 3 Dell Inspiron 15-7559 Battery Replacement: étape 3, image 2 de 3 Dell Inspiron 15-7559 Battery Replacement: étape 3, image 3 de 3
    • Use the blue, plastic opening tool to gently pry a section of the back panel open.
    • Next slide the opening tool around the back panel to disconnect the clips holding the panel in place.
    • After the clips have been disconnected, the back panel can then be easily lifted off the computer.
  4. Dell Inspiron 15-7559 Battery Replacement, Battery: étape 4, image 1 de 1
    • Locate the battery on the bottom left side of the laptop.
  5. Dell Inspiron 15-7559 Battery Replacement: étape 5, image 1 de 3 Dell Inspiron 15-7559 Battery Replacement: étape 5, image 2 de 3 Dell Inspiron 15-7559 Battery Replacement: étape 5, image 3 de 3
    • Unscrew the 5 x 2mm x 5mm screws, using the T8 Torx screwdriver.
  6. Dell Inspiron 15-7559 Battery Replacement: étape 6, image 1 de 3 Dell Inspiron 15-7559 Battery Replacement: étape 6, image 2 de 3 Dell Inspiron 15-7559 Battery Replacement: étape 6, image 3 de 3
    • Using the tab above the battery, raise the battery far enough to disconnect the cables attached to it.
    • Using your hand grab the white portion connecting the cables to the battery and disconnect it.
    • Do not pull on the cables directly. This would risk damaging them or tearing them from the device.
  7. Dell Inspiron 15-7559 Battery Replacement: étape 7, image 1 de 1
    • Now lift the battery from the device to remove it.
11 autres ont terminé cette réparation.
Trenton Greevebiester
Membre depuis le 10/19/17
1 587 Réputation
6 tutoriels rédigés
Équipe
UW Tacoma, Team S3-G2, Liner Fall 2017 Membre de l'équipe UW Tacoma, Team S3-G2, Liner Fall 2017
UWT-LINER-F17S3G2
5 membres
9 tutoriels rédigés
2 commentaires
Cool, that’s the easy part. How do you tell the UEFI that it’s okay to charge the new battery?
Stefan Bacon - Réponse
is it ok to replace the 11.4V battery with the 11.1V version?
Payton DePietro - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 36
30 derniers jours : 95
Total : 16,942
