Aller au contenu principal
Dell Inspiron 1525 Central Control Cover Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 1525 Central Control Cover Replacement, Battery: étape 1, image 1 de 1
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron 1525 Central Control Cover Replacement: étape 2, image 1 de 2 Dell Inspiron 1525 Central Control Cover Replacement: étape 2, image 2 de 2
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron 1525 Central Control Cover Replacement, Central Control Cover: étape 3, image 1 de 1
    • Remove the two 4.00 mm Phillips #1 screws from the battery tray.
  4. Dell Inspiron 1525 Central Control Cover Replacement: étape 4, image 1 de 3 Dell Inspiron 1525 Central Control Cover Replacement: étape 4, image 2 de 3 Dell Inspiron 1525 Central Control Cover Replacement: étape 4, image 3 de 3
    • Insert the flat end of a spudger into the slot on the right side of the central control cover and pry it up.
    • Carefully pull the central control cover up along its edges.
    • Do not attempt to completely remove the cover, as it is still attached via a ribbon cable.
  5. Dell Inspiron 1525 Central Control Cover Replacement: étape 5, image 1 de 3 Dell Inspiron 1525 Central Control Cover Replacement: étape 5, image 2 de 3 Dell Inspiron 1525 Central Control Cover Replacement: étape 5, image 3 de 3
    • Peel back the silver tape securing the ribbon cable to the cover.
    • Pull the small brown latch on the ribbon cable connector out.
    • Disconnect the ribbon cable to completely free the central control cover.
3 autres ont terminé cette réparation.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 8
Total : 3,603
