Aller au contenu principal
Dell Inspiron 1525 RAM Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 1525 RAM Replacement, Battery: étape 1, image 1 de 1
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron 1525 RAM Replacement: étape 2, image 1 de 2 Dell Inspiron 1525 RAM Replacement: étape 2, image 2 de 2
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron 1525 RAM Replacement, Bottom Cover: étape 3, image 1 de 2 Dell Inspiron 1525 RAM Replacement, Bottom Cover: étape 3, image 2 de 2
    • Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
    • The screws may only need to be loosened, as they are generally retained by plastic washers.
    • Remove the bottom panel.
  4. Dell Inspiron 1525 RAM Replacement, RAM: étape 4, image 1 de 3 Dell Inspiron 1525 RAM Replacement, RAM: étape 4, image 2 de 3 Dell Inspiron 1525 RAM Replacement, RAM: étape 4, image 3 de 3
    • Push the white tabs on either side of the RAM chip outward. The chip should pop up a little.
    • Carefully remove the RAM chip by pulling it out at a slight vertical angle.
  5. Dell Inspiron 1525 RAM Replacement: étape 5, image 1 de 2 Dell Inspiron 1525 RAM Replacement: étape 5, image 2 de 2
    • Remove the lower RAM chip in the same fashion as the upper one.
5 autres ont terminé cette réparation.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 10,871
