Introduction
This guide will show you how to remove and replace the processor unit.
Outils
Pièces
Aucune pièce spécifiée.
Remove the battery from the bottom of the laptop.
Please click on the following link for further instruction on how to remove the battery. Dell Inspiron 9100 Battery Replacement
Insert a spludger into the notch at the far left side of the top blue panel and pry hinge cover off.
Note: You may need to pry the other side off by inserting the spludger between the hinge and the top cover.
Flip the laptop over and remove the indicated screws.
Flip the laptop back over.
Find the two places where the display module is attached to the base of the computer.
Locate and remove the top two screws and all the screws on the underside holding the top case down.
Gently pop off the top plastic case from the unit.
3 autre(s) ont terminé cette réparation.
2 commentaires
you can actually Simplify this a Lot by removing the fan on the bottom shown in Step 1 upper Right side then once you get to step 8 you only have to remove the screws for the processor heatsink and then bam your processor is able to be removed or replaced
DW
The Dell Inspiron 8600 I have (not sure the year) I had to remove the keyboard to access the CPU.. Remove two screws holding the keyboard down and lift on the white tab. Remove the fan (two screws and the fan comes right out).. That give you more room to remove the heat exchanger. Other than that it was SUPER EASY !!! Thanks
