Aller au contenu principal
Dell Inspiron 9300 Processor Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 9300 Processor Replacement, Prerequisite Only: étape 1, image 1 de 2 Dell Inspiron 9300 Processor Replacement, Prerequisite Only: étape 1, image 2 de 2
    • Remove the battery prior to working on any internal components.
    • Remove the twelve 6mm Phillips screws from the bottom of the case.
    • Remove the battery before working on internal components to ensure a safe working environment.
  2. Dell Inspiron 9300 Processor Replacement: étape 2, image 1 de 1
    • Gently pry away the silver bezel above the keyboard and below the display using a spudger.
    • Start on the right hand side, where there is a notch in the bezel for easiest removal.
  3. Dell Inspiron 9300 Processor Replacement: étape 3, image 1 de 3 Dell Inspiron 9300 Processor Replacement: étape 3, image 2 de 3 Dell Inspiron 9300 Processor Replacement: étape 3, image 3 de 3
    • Remove the two 5mm Phillips screws retaining the keyboard.
    • Pull the keyboard up and toward the monitor to reveal the ribbon cable beneath.
    • Firmly grasp the blue tape attached to the keyboard ribbon cable connector and pull upward away from the motherboard.
  4. Dell Inspiron 9300 Processor Replacement: étape 4, image 1 de 2 Dell Inspiron 9300 Processor Replacement: étape 4, image 2 de 2
    • Firmly grasp the blue tape attached to the LCD display ribbon cable connector and pull upward away from the motherboard.
    • Remove the two 5mm Phillips screws holding the display hinge on both sides of the laptop.
    • Support the display as you loosen the hinges, to avoid the screen falling and breaking.
  5. Dell Inspiron 9300 Processor Replacement: étape 5, image 1 de 2 Dell Inspiron 9300 Processor Replacement: étape 5, image 2 de 2
    • Remove the seven 6mm Phillips screws holding the trackpad/palm rest to the motherboard.
    • Gently pry the CMOS battery out of its retaining clip using a spudger.
  6. Dell Inspiron 9300 Processor Replacement: étape 6, image 1 de 2 Dell Inspiron 9300 Processor Replacement: étape 6, image 2 de 2
    • Remove the low profile connector for the keyboard status lights located next to the video card heat sink using a spudger.
    • Remove the trackpad ribbon cable from the motherboard using a spudger.
  7. Dell Inspiron 9300 Processor Replacement: étape 7, image 1 de 2 Dell Inspiron 9300 Processor Replacement: étape 7, image 2 de 2
    • Pull up and away on the track pad to expose the internal components below.
  8. Dell Inspiron 9300 Processor Replacement, Processor: étape 8, image 1 de 1
    • Loosen the four silver Phillips screws in a criss-cross pattern retaining the heatsink to the cpu.
  9. Dell Inspiron 9300 Processor Replacement: étape 9, image 1 de 1
    • Gently lift up on the heatsink to reveal the CPU below.
  10. Dell Inspiron 9300 Processor Replacement: étape 10, image 1 de 2 Dell Inspiron 9300 Processor Replacement: étape 10, image 2 de 2
    • Gently loosen but do not remove the flathead screw.
    • Lift the CPU away from the motherboard, taking care to not damage the gold pins.
    • You will have to remove and replace the Comment appliquer de la pâte thermique on the CPU base.
Steven Faulkner
Membre depuis le 11/10/16
490 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 16-6, Eyestone Fall 2016 Membre de l'équipe USF Tampa, Team 16-6, Eyestone Fall 2016
USFT-EYESTONE-F16S16G6
5 membres
11 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 934
