Introduction
This guide will take you through removing the display. This may be a necessary process if the display is not functioning properly or is broken. The display panel and motherboard are extremely fragile so remember when replacing to handle with care and consider placing onto a towel.
Ce dont vous avez besoin
Using a prying tool, gently pry the palm rest off of the palm rest bracket. Start prying from one side and slowly work your way around.
Gently pull the touchpad cable off the palm rest bracket.
Lift the rest of the palm rest off the computer base.
Close the device and turn over.
Remove the five 8mm Phillips 0 screws.
Remove the following:
Two 4mm Phillips screws securing the motherboard
AC adapter cable
USB and SIM card cable connector
Display cable connector
Carefully lift the motherboard out.
Pull the Mini-Card cables out of the computer base. They slide out from under a few pieces of plastic that secure them to the base.
