Introduction
Use this guide to replace a worn out or damaged battery in your Dell Latitude 7410 laptop.
If your laptop dies quickly or doesn't hold a charge, it might be time to replace the battery.
If your battery is swollen, take appropriate precautions.
Ce dont vous avez besoin
Unplug all cables, fully shut down your laptop, and close the lid.
Use a Phillips screwdriver to loosen the eight captive screws securing the back cover.
Insert an opening pick between the right edge of the back cover and the frame, just below the middle right screw.
Slide your pick along the right edge to release the clips securing the back cover.
Insert your pick between the left edge of the back cover and the frame, next to the speaker cutout.
Slide your pick along the left edge to release the clips.
Insert your pick between the back cover and the right display-hinge to release the first clip along the back edge.
Slide your pick toward the left hinge until the second clip releases.
Insert your pick between the front edge of the back cover and the frame, just to the right of the bottom left screw.
Slide your pick toward the right edge until the front edge releases from the frame.
Grab the black pull tab on the head of the battery connector and pull straight up to disconnect it.
Use your Phillips screwdriver to loosen the four captive screws securing the battery.
For optimal performance, calibrate your newly installed battery after completing this guide.
