Aller au contenu principal
Dell Latitude 9410 2-in-1 SSD Replacement
Ce dont vous avez besoin
  1. Dell Latitude 9410 2-in-1 SSD Replacement, Base Panel: étape 1, image 1 de 1
    • Ensure that the laptop is unplugged and powered off before beginning.
    • Place the laptop upside down on a flat surface.
  2. Dell Latitude 9410 2-in-1 SSD Replacement: étape 2, image 1 de 2 Dell Latitude 9410 2-in-1 SSD Replacement: étape 2, image 2 de 2
    • Use a Phillips #00 screwdriver to loosen the ten captive screws.
    • The screws are permanently fastened to the base panel; do not attempt to remove them.
  3. Dell Latitude 9410 2-in-1 SSD Replacement: étape 3, image 1 de 3 Dell Latitude 9410 2-in-1 SSD Replacement: étape 3, image 2 de 3 Dell Latitude 9410 2-in-1 SSD Replacement: étape 3, image 3 de 3
    • Carefully lift off the back panel.
  4. Dell Latitude 9410 2-in-1 SSD Replacement, SSD: étape 4, image 1 de 3 Dell Latitude 9410 2-in-1 SSD Replacement, SSD: étape 4, image 2 de 3 Dell Latitude 9410 2-in-1 SSD Replacement, SSD: étape 4, image 3 de 3
    • Carefully peel back and remove the black tape around the top left corner of the motherboard.
  5. Dell Latitude 9410 2-in-1 SSD Replacement: étape 5, image 1 de 3 Dell Latitude 9410 2-in-1 SSD Replacement: étape 5, image 2 de 3 Dell Latitude 9410 2-in-1 SSD Replacement: étape 5, image 3 de 3
    • Use a Phillips #00 screwdriver to remove the 2 mm screw, loosening the bracket that covers the SSD.
    • Carefully lift the off the bracket.
    • The bracket is attached to the laptop and cannot be removed completely.
  6. Dell Latitude 9410 2-in-1 SSD Replacement: étape 6, image 1 de 3 Dell Latitude 9410 2-in-1 SSD Replacement: étape 6, image 2 de 3 Dell Latitude 9410 2-in-1 SSD Replacement: étape 6, image 3 de 3
    • Grip the SSD and pull directly backward until the SSD releases from its port.
Jessica Stephens
Membre depuis le 02/08/22
558 Réputation
5 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 41
Total : 985
