Aller au contenu principal
Dell Studio 1535 Keyboard Replacement
Ce dont vous avez besoin
  1. Dell Studio 1535 Keyboard Replacement, Keyboard: étape 1, image 1 de 3 Dell Studio 1535 Keyboard Replacement, Keyboard: étape 1, image 2 de 3 Dell Studio 1535 Keyboard Replacement, Keyboard: étape 1, image 3 de 3
    • Gather materials and tools
    • Flip laptop over
    • Remove battery and power cord before doing anything
  2. Dell Studio 1535 Keyboard Replacement: étape 2, image 1 de 2 Dell Studio 1535 Keyboard Replacement: étape 2, image 2 de 2
    • Where the battery was, take out the two screws with the letter "K" next to them
    • Save the screws somewhere safe, and flip the laptop rightside up
  3. Dell Studio 1535 Keyboard Replacement: étape 3, image 1 de 3 Dell Studio 1535 Keyboard Replacement: étape 3, image 2 de 3 Dell Studio 1535 Keyboard Replacement: étape 3, image 3 de 3
    • Open the laptop
    • Take the flathead screwdriver, and put it under the bezel that goes around the keyboard
    • If you're simply fixing the existing keyboard, be careful not to pry a key off. They are close to impossible to get back on
    • Pry the bezel out of the frame. It might take some effort, but this is the correct method
    • Once one part has snapped out of the frame, continue to carefully remove the rest of the bezel
  4. Dell Studio 1535 Keyboard Replacement: étape 4, image 1 de 3 Dell Studio 1535 Keyboard Replacement: étape 4, image 2 de 3 Dell Studio 1535 Keyboard Replacement: étape 4, image 3 de 3
    • Once the bezel is removed, put the screwdriver under the media control bar
    • Continue to apply pressure, prying it out of place; it should snap out easy
    • Do not rip it out without precaution. It's attached with a delicate ribbon cable, and if damaged, you'll be replacing more than the keyboard
    • Once snapped out of it's place, flip it over gently onto the keyboard
  5. Dell Studio 1535 Keyboard Replacement: étape 5, image 1 de 2 Dell Studio 1535 Keyboard Replacement: étape 5, image 2 de 2
    • Unscrew the two screws at the top of the keyboard using the Phillips screwdriver
    • Set the screws aside along with the other ones. They are the same size, no need to worry about getting them mixed up
  6. Dell Studio 1535 Keyboard Replacement: étape 6, image 1 de 3 Dell Studio 1535 Keyboard Replacement: étape 6, image 2 de 3 Dell Studio 1535 Keyboard Replacement: étape 6, image 3 de 3
    • Now that the screws are out, lift the top of the keyboard
    • You will notice some resistance due to clips on the sides. Lift the side of the keyboard gently, taking the board out of the clip without breaking it
    • Once both sides are out of the clips, slide the keyboard forward a bit
    • Flip the keyboard over, minding the ribbon cable, over onto the palmrest
  7. Dell Studio 1535 Keyboard Replacement: étape 7, image 1 de 3 Dell Studio 1535 Keyboard Replacement: étape 7, image 2 de 3 Dell Studio 1535 Keyboard Replacement: étape 7, image 3 de 3
    • Now that they physical keyboard is removed, we can focus on the ribbon cable
    • Caution, this step can make or break the connection point, so be gentle
    • Gently flip the black hatch part of the connection point upwards
    • Remove the ribbon cable from the connection point
    • When re-installing the cable, be sure that it is inserted all the way, and that the hatch is closed. If not, it may malfunction, or not work at all, and you will have to do this all over again
  8. Dell Studio 1535 Keyboard Replacement: étape 8, image 1 de 2 Dell Studio 1535 Keyboard Replacement: étape 8, image 2 de 2
    • Congratulations, you've successfully removed the keyboard!
9 autres ont terminé cette réparation.
Eric Bentley
Membre depuis le 05/14/11
1 350 Réputation
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 3
Total : 13,447
