Aller au contenu principal
Dell Vostro 1320 USB Port Replacement
Ce dont vous avez besoin
  1. Dell Vostro 1320 USB Port Replacement, USB Port: étape 1, image 1 de 1
    • Remove the battery from the computer.
  2. Dell Vostro 1320 USB Port Replacement: étape 2, image 1 de 1
    • Remove all visible screws from the bottom of the computer.
  3. Dell Vostro 1320 USB Port Replacement: étape 3, image 1 de 3 Dell Vostro 1320 USB Port Replacement: étape 3, image 2 de 3 Dell Vostro 1320 USB Port Replacement: étape 3, image 3 de 3
    • Use a metal spudger to remover the covers of each section that you removed screws from.
    • Once the cover is removed from the hard drive remove the hard drive by gently tugging it out.
  4. Dell Vostro 1320 USB Port Replacement: étape 4, image 1 de 1
  5. Dell Vostro 1320 USB Port Replacement: étape 5, image 1 de 3 Dell Vostro 1320 USB Port Replacement: étape 5, image 2 de 3 Dell Vostro 1320 USB Port Replacement: étape 5, image 3 de 3
    • You must first unscrew the screws holding the wire in place.
    • Unhook the wire that the metal spudger is pointing at.
  6. Dell Vostro 1320 USB Port Replacement: étape 6, image 1 de 1
  7. Dell Vostro 1320 USB Port Replacement: étape 7, image 1 de 2 Dell Vostro 1320 USB Port Replacement: étape 7, image 2 de 2
    • Undo the screws holding the screen to the computer base.
  8. Dell Vostro 1320 USB Port Replacement: étape 8, image 1 de 1
    • Unplug the wires connecting the screen to the base.
    • The screen should come free and is able to be removed completely.
  9. Dell Vostro 1320 USB Port Replacement: étape 9, image 1 de 2 Dell Vostro 1320 USB Port Replacement: étape 9, image 2 de 2
    • Unplug the two blue labeled wires.
  10. Dell Vostro 1320 USB Port Replacement: étape 10, image 1 de 3 Dell Vostro 1320 USB Port Replacement: étape 10, image 2 de 3 Dell Vostro 1320 USB Port Replacement: étape 10, image 3 de 3
    • Detach the black plastic cover by loosening it with a metal spudger.
  11. Dell Vostro 1320 USB Port Replacement: étape 11, image 1 de 1
    • Unplug the wire that the metal spudger is pointing to.
  12. Dell Vostro 1320 USB Port Replacement: étape 12, image 1 de 1
    • Unscrew the USB port.
  13. Dell Vostro 1320 USB Port Replacement: étape 13, image 1 de 2 Dell Vostro 1320 USB Port Replacement: étape 13, image 2 de 2
    • Gently lift out the USB port.
Christie Lloyd
Membre depuis le 08/26/15
431 Réputation
4 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 13
Total : 647
