Introduction
The device featured in this replacement guide is the Dell XPS 14 L421X. This guide will assist the user in removing and replacing the laptop's Wi-Fi card. The Wi-Fi card connects the device to the internet through a wireless connection to a local network. There are no special skills or requirements for this guide, the user will only need to complete the steps shown. The Wi-Fi card may often be the cause for poor Wi-Fi connection. For more troubleshooting information, refer to the troubleshooting page. Before fully removing the Wi-Fi card, make sure you check to ensure that the card is connected to the device, as these symptoms may also be due to a loose cable or plug. Before following these steps, it is important that you ground yourself. You can do so by wearing an anti-static wrist strap. Also, make sure that the battery is fully disconnected before removing the Wi-Fi card.
Ce dont vous avez besoin
Position the computer back side up so that the “XPS” logo is facing you.
Remove six 3 mm screws along the perimeter of the back panel using a T5 Torx screwdriver.
Flip over the back panel so that the interior of the panel is facing up.
Remove three 2 mm screws that are connected to the vendor GCE disk on the bottom left corner of the back panel using a Phillips #0 screwdriver.
Remove the black plastic cover that holds the disk in place.
Remove the back panel.
Remove four 2 mm screws that are connected to the speaker using a Phillips #0 screwdriver.
Remove the four 6 mm screws from the sides of the battery using a T5 Torx screwdriver.
Remove the two 3 mm screws from the top of the battery using a Phillips #0 screwdriver.
Remove the Wi-Fi card by gently lifting the card and pulling it out of its slot.
