Introduction
Replacing the battery of a Dell XPS 15 9510 laptop is a straightforward task requiring only a few tools. The new battery constitutes nearly all of the cost of this repair, so if you are planning to order a replacement battery for this or any other laptop, it may be wise to remove the back panel of the laptop to ensure that the one you are ordering matches the existing one.
If the battery you are replacing is swollen, be sure to take appropriate precautions.
Ce dont vous avez besoin
Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
Lift the back panel of the laptop off and set it aside.
Please do not miss this warning of it being sharp...
After opening a few laptops for my office, I have generally been fine. But after opening my own XPS... I had sliced my finger badly. -
Using the small battery pull tab, disconnect the battery connector from the motherboard.
5 autres ont terminé cette réparation.
Un commentaire
XPS 15 9510 states the battery (purchased from ifixit) is FAKE and the battery will not charge.
