Aller au contenu principal
Dell XPS 15 9530 Motherboard Replacement
Ce dont vous avez besoin
  1. Dell XPS 15 9530 Motherboard Replacement, Fan: étape 1, image 1 de 3 Dell XPS 15 9530 Motherboard Replacement, Fan: étape 1, image 2 de 3 Dell XPS 15 9530 Motherboard Replacement, Fan: étape 1, image 3 de 3
    • Turn the laptop upside down.
    • Unscrew ten 3 mm screws on the back cover with a Torx T5 screwdriver.
    • Remove two more 3 mm screws with a Phillips #0 screwdriver.
  2. Dell XPS 15 9530 Motherboard Replacement: étape 2, image 1 de 2 Dell XPS 15 9530 Motherboard Replacement: étape 2, image 2 de 2
    • Use the Phillips #0 screwdriver to unscrew the three screws on each fan.
  3. Dell XPS 15 9530 Motherboard Replacement: étape 3, image 1 de 2 Dell XPS 15 9530 Motherboard Replacement: étape 3, image 2 de 2
    • Use metal tweezers to carefully unplug the fan cables from the motherboard.
  4. Dell XPS 15 9530 Motherboard Replacement: étape 4, image 1 de 1
    • Remove the fans by gently lifting up the edges until the fans disconnect from the motherboard completely.
  5. Dell XPS 15 9530 Motherboard Replacement, Battery: étape 5, image 1 de 2 Dell XPS 15 9530 Motherboard Replacement, Battery: étape 5, image 2 de 2
    • Using a Phillips #0 screwdriver, remove the seven 3.5mm screws that secure the battery to the palm rest assembly.
  6. Dell XPS 15 9530 Motherboard Replacement: étape 6, image 1 de 1
    • Disconnect the battery cable from the system board.
    • Be sure to use a plastic tool, not a metal one.
  7. Dell XPS 15 9530 Motherboard Replacement: étape 7, image 1 de 1
    • Lift the battery off the chassis.
  8. Dell XPS 15 9530 Motherboard Replacement, Motherboard: étape 8, image 1 de 3 Dell XPS 15 9530 Motherboard Replacement, Motherboard: étape 8, image 2 de 3 Dell XPS 15 9530 Motherboard Replacement, Motherboard: étape 8, image 3 de 3
    • Using both hands and plastic tweezers, disconnect the cables from the laptop base.
  9. Dell XPS 15 9530 Motherboard Replacement: étape 9, image 1 de 2 Dell XPS 15 9530 Motherboard Replacement: étape 9, image 2 de 2
    • Use phillips #0 screwdriver to unscrew the screws connecting the motherboard and the laptop base.
    • Lift up the motherboard with the plastic fan holder on top of it.
  10. Dell XPS 15 9530 Motherboard Replacement: étape 10, image 1 de 3 Dell XPS 15 9530 Motherboard Replacement: étape 10, image 2 de 3 Dell XPS 15 9530 Motherboard Replacement: étape 10, image 3 de 3
    • Use T5 Torx screwdriver to unscrew the screws connecting the plastic fan holder and the motherboard.
Matt
Membre depuis le 10/02/19
171 Réputation
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 12
30 derniers jours : 38
Total : 1,298
