Aller au contenu principal
Dell XPS 15 9560 Battery Replacement
Ce dont vous avez besoin
  1. Dell XPS 15 9560 Battery  Replacement, Back Panel: étape 1, image 1 de 1
    • Using a T5 Torx screwdriver, remove ten 4.0 mm screws from the back panel of the laptop.
  2. Dell XPS 15 9560 Battery  Replacement: étape 2, image 1 de 1
    • Using a Phillips #2 screwdriver, remove two 5.0 mm screws underneath the XPS badge door.
  3. Dell XPS 15 9560 Battery  Replacement: étape 3, image 1 de 1
    • Wedge the scribe between the backplate and remove the bottom base cover.
  4. Dell XPS 15 9560 Battery  Replacement, Battery: étape 4, image 1 de 1
    • Using a T5 Torx screwdriver, remove the six 4.0 mm screws.
  5. Dell XPS 15 9560 Battery  Replacement: étape 5, image 1 de 1
    • Unplug the battery cable.
  6. Dell XPS 15 9560 Battery  Replacement: étape 6, image 1 de 1
    • Remove the battery.
For optimal performance, after completing this guide, calibrate your newly installed battery.
8 autres ont terminé cette réparation.
Jada Houser
Membre depuis le 09/28/21
790 Réputation
7 tutoriels rédigés
Équipe
Clemson, Team 4-5, Hunter Fall 2021 Membre de l'équipe Clemson, Team 4-5, Hunter Fall 2021
CLEM-HUNTER-F21S4G5
4 membres
15 tutoriels rédigés
Un commentaire
If you have an additional HDD you need to use the type H5H20 instead of the 6GPTY. The configuration as shown in picture 6 isn't possible with the 6GPTY unless you're willing to remove the HDD.
Tim - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 10
7 derniers jours : 76
30 derniers jours : 297
Total : 9,153
