Aller au contenu principal
Dewalt DCF885 Motor Assembly Replacement
Ce dont vous avez besoin
  1. Dewalt DCF885 Motor Assembly Replacement, Battery: étape 1, image 1 de 1
    • Press the battery release button at the top of the battery.
  2. Dewalt DCF885 Motor Assembly Replacement: étape 2, image 1 de 1
    • Pull the battery away from the tool.
  3. Dewalt DCF885 Motor Assembly Replacement, Motor Assembly: étape 3, image 1 de 1
    • Remove the eight 18 mm Torx Security #10 screws.
  4. Dewalt DCF885 Motor Assembly Replacement: étape 4, image 1 de 1
    • Separate the two halves of the outer case. Set the empty side down and out of the way.
  5. Dewalt DCF885 Motor Assembly Replacement: étape 5, image 1 de 1
    • Disconnect the connector from the motor assembly.
  6. Dewalt DCF885 Motor Assembly Replacement: étape 6, image 1 de 1
    • Pull the motor away from the brush assembly.
Will
Membre depuis le 01/29/19
324 Réputation
2 tutoriels rédigés
Un commentaire
That's not the motor assembly. That's the Gearbox. The motor and brush assembly are together in the rear of the drill.
John B - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 22
30 derniers jours : 52
Total : 2,875
