Introduction
This guide shows how to remove and reinstall a driver blade for the Dewalt Nailers DCN660D1 2018.
Ce dont vous avez besoin
Use a T10 driver to remove the ten screws securing the outer housing.
Lay the device on its left side (with the belt hook).
Lift and remove the right housing from the device.
Be sure to route the wires through the yellow groove.
Be sure to reattach the spring clips.
Carefully flip the device over.
Remove the left housing from the device.
Use a T25 driver to remove the two screws (one on either side) securing the back support .
Grasp the driver assembly by its back and pull it straight out of the device.
Use pliers or a flathead screwdriver to straighten the retaining clip securing the blade.
Slide the blade through the slot in the driver assembly and set it into the wavy groove.
Insert the retaining clip oriented as shown in the photos into the driver assembly.
3 autres ont terminé cette réparation.
3 commentaires
This is helpful, should any oil be used during reassembly of the driver unit? Thanks.
Thanks for this guide! I was able to get it apart and diagnose the problem on my own, but %#*@ if I could have got it back together without this. Nail gun saved!
