Aller au contenu principal
Digiland 10.1'' DL1016 Speakers Replacement
Ce dont vous avez besoin
  1. Attention : les étapes 1 à 2 sont issues d'un tutoriel marqué comme en cours.
    Digiland 10.1'' DL1016 Speakers Replacement, Digiland 10.1'' DL1016 Remove Backing: étape 1, image 1 de 2 Digiland 10.1'' DL1016 Speakers Replacement, Digiland 10.1'' DL1016 Remove Backing: étape 1, image 2 de 2
    • Use an opening pick and an opening tool to pry the backing off the back of the tablet.
    • You may need some force when doing this and if needed use a metal spudger.
  2. Digiland 10.1'' DL1016 Speakers Replacement: étape 2, image 1 de 2 Digiland 10.1'' DL1016 Speakers Replacement: étape 2, image 2 de 2
    • Gently lift the backing off.
  3. Digiland 10.1'' DL1016 Speakers Replacement, Digiland 10.1'' DL1016 Disconnect LCD Connectors: étape 3, image 1 de 3 Digiland 10.1'' DL1016 Speakers Replacement, Digiland 10.1'' DL1016 Disconnect LCD Connectors: étape 3, image 2 de 3 Digiland 10.1'' DL1016 Speakers Replacement, Digiland 10.1'' DL1016 Disconnect LCD Connectors: étape 3, image 3 de 3
    • Pull back the black flaps on the ZIF cable connectors.
    • Pull the ribbon cables out of the connectors.
  4. Attention : l'étape 4 est issue d'un tutoriel marqué comme en cours.
    Digiland 10.1'' DL1016 Speakers Replacement, Digiland 10.1'' DL1016 Remove Battery: étape 4, image 1 de 2 Digiland 10.1'' DL1016 Speakers Replacement, Digiland 10.1'' DL1016 Remove Battery: étape 4, image 2 de 2
    • Use an ESD safe pryer to lift the battery up.
    • There is glue that holds the battery down, so carefully pry it open. You may need to use some force.
  5. Digiland 10.1'' DL1016 Speakers Replacement, Speakers: étape 5, image 1 de 3 Digiland 10.1'' DL1016 Speakers Replacement, Speakers: étape 5, image 2 de 3 Digiland 10.1'' DL1016 Speakers Replacement, Speakers: étape 5, image 3 de 3
    • The speakers are marked in red.
    • Disconnect the speaker connections.
    • Remove the speakers.
Jose Luis Rodriguez
Membre depuis le 08/26/19
73 Réputation
1 tutoriel rédigé
Équipe
Gateway, Team S1-G2, Saknee Fall 2019 Membre de l'équipe Gateway, Team S1-G2, Saknee Fall 2019
GCC-SAKNEE-F19S1G2
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 115
