Aller au contenu principal
Disassembling Fujifilm X30 Camera
Ce dont vous avez besoin
  1. Disassembling Fujifilm X30 Camera, Battery: étape 1, image 1 de 2 Disassembling Fujifilm X30 Camera, Battery: étape 1, image 2 de 2
    • Turn the camera upside down.
    • Place your thumb on the switch, and slide it towards the center of the camera.
    • The compartment will pop open.
  2. Disassembling Fujifilm X30 Camera: étape 2, image 1 de 1
    • Once you have the battery compartment open, slide the orange tab away from the battery until it ejects.
  3. Disassembling Fujifilm X30 Camera: étape 3, image 1 de 1
    • Pull the battery out.
  4. Disassembling Fujifilm X30 Camera, Motherboard: étape 4, image 1 de 3 Disassembling Fujifilm X30 Camera, Motherboard: étape 4, image 2 de 3 Disassembling Fujifilm X30 Camera, Motherboard: étape 4, image 3 de 3
    • Begin by removing the outside screws using a Phillips #000 Screwdriver:
    • Remove the three 3.6 mm silver screws located on the bottom of the camera.
    • Remove all four of the 4.7 mm screws from the sides of the camera.
  5. Disassembling Fujifilm X30 Camera: étape 5, image 1 de 2 Disassembling Fujifilm X30 Camera: étape 5, image 2 de 2
    • Remove all screws below using a Phillips #000 Screwdriver:
    • Lift up the screen and remove the two 4.5 mm screws located in the bottom corners.
    • Remove the 4.0 mm screw that is located behind the screen and directly under the eye piece.
  6. Disassembling Fujifilm X30 Camera: étape 6, image 1 de 1
    • Carefully lift up the bottom piece of the camera to remove it.
  7. Disassembling Fujifilm X30 Camera: étape 7, image 1 de 1
    • Do not pull hard when removing the backing because it could rip the orange strip attached to the motherboard.
    • Gently pull off the back of the camera from the left side so that it is partially open.
    • Use a spudger to lift up the tab holding the orange strip and slide the strip out to disconnect it
    • Refer to the next step to see pictures of how to properly use the spudger when removing a strip.
  8. Disassembling Fujifilm X30 Camera: étape 8, image 1 de 3 Disassembling Fujifilm X30 Camera: étape 8, image 2 de 3 Disassembling Fujifilm X30 Camera: étape 8, image 3 de 3
    • For all five indicated orange strips:
    • Use a spudger to lift up the tab holding the orange strip and slide the strip out to disconnect it.
  9. Disassembling Fujifilm X30 Camera: étape 9, image 1 de 1
    • For the last orange strip located behind the top strip:
  10. Disassembling Fujifilm X30 Camera: étape 10, image 1 de 1
    • This step is required if you are doing a full disassembly, but can be skipped if you are only removing the motherboard.
    • For the two orange strips attached to the capacitor circuitboard:
  11. Disassembling Fujifilm X30 Camera: étape 11, image 1 de 3 Disassembling Fujifilm X30 Camera: étape 11, image 2 de 3 Disassembling Fujifilm X30 Camera: étape 11, image 3 de 3
    • Remove all screws listed below using a Phillips #000 screwdriver:
    • Remove the two 3.4 mm screws at the bottom of the silver plate.
    • Hold back the clear strip to reveal a 2.8 mm screw on the left of the silver plate and remove it.
    • Peel back the copper plate.
  12. Disassembling Fujifilm X30 Camera: étape 12, image 1 de 1
    • Remove the three 2.6 mm screws located in the top two corners and the bottom right corner of the motherboard using a Phillips #000 screwdriver.
  13. Disassembling Fujifilm X30 Camera: étape 13, image 1 de 2 Disassembling Fujifilm X30 Camera: étape 13, image 2 de 2
    • Tilt up the motherboard to locate the black, grey, and red wires.
    • Desolder these wires in order to completely remove the motherboard.
    • You can learn about soldering techniques here.
  14. Disassembling Fujifilm X30 Camera, Disassembling Fujifilm X30 Camera: étape 14, image 1 de 1
    • Remove the four 4.4 mm silver screws at the corners of the lens using a Phillips #000 screwdriver.
  15. Disassembling Fujifilm X30 Camera: étape 15, image 1 de 2 Disassembling Fujifilm X30 Camera: étape 15, image 2 de 2
    • Pull the lens toward the bottom of the camera so it can clear the silver tab.
    • Then push the lens with your index fingers from the front of the camera until it is removed.
  16. Disassembling Fujifilm X30 Camera: étape 16, image 1 de 2 Disassembling Fujifilm X30 Camera: étape 16, image 2 de 2
    • Do not touch the leads on the capacitor below the green circuitboard because they can shock you.
    • Remove the silver 3.4 mm screw from the top left corner of the capacitor circuitboard using a Phillips #000 screwdriver.
    • Desolder the red, black, grey, and green wires attached to the capacitor circuitboard so the circuitboard is disconnected and can be set aside.
  17. Disassembling Fujifilm X30 Camera: étape 17, image 1 de 2 Disassembling Fujifilm X30 Camera: étape 17, image 2 de 2
    • Rotate the camera so you are looking at the bottom.
    • Remove the two silver 3.4 mm screws on the silver plate that are holding the eyepiece using a Phillips #000 screwdriver.
    • Lift the eyepiece out of the camera.
  18. Disassembling Fujifilm X30 Camera: étape 18, image 1 de 2 Disassembling Fujifilm X30 Camera: étape 18, image 2 de 2
    • To remove the LCD screen, look at the back of the tiltable screen plate.
    • Remove the two black 3.7 mm screws in the back corners of the screen plate using a Phillips #000 screwdriver.
    • Lay the back panel flat to lift off the clear casing that is over the LCD screen.
  19. Disassembling Fujifilm X30 Camera: étape 19, image 1 de 1
    • You have disassembled the Fujifilm X30 camera!
9 autres ont terminé cette réparation.
Jay Sterner
Membre depuis le 01/12/16
450 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 70-3, Forte Winter 2016 Membre de l'équipe Cal Poly, Team 70-3, Forte Winter 2016
CPSU-FORTE-W16S70G3
5 membres
4 tutoriels rédigés
2 commentaires
the big question is how to repair the common stuck open flash?
Don Makaveli - Réponse
and the broken battery latch (orange tab)? Thanks.
yoyoy - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 54
30 derniers jours : 164
Total : 13,851
