Introduction
This is a Bluetooth speaker that can be used outdoors for easy portability. The unit was purchased a few years ago, so it is used for dismantling for research due to impaired playback sound quality. You can find more information about this device on this website.
Ce dont vous avez besoin
BUILT FOR LIFE ON THE ROAD, THIS COMPACT PORTABLE SPEAKER OFFERS 20 + HOURS OF PLAYTIME.
Echoing the legacy of rock ‘n’ roll, Stockwell II has a solid metal grille that pays homage to the steel mesh grille found on many microphones and a guitar inspired carry strap for easy portability.
Its roadworthy construction with silicone exterior and IPX4 waterresistant rating make it extremely rugged and durable.
Total weight: 1400g
Length: 161mm
Width: 70mm
Height: 180mm (without carrying strap)
Remove the handle by unscrewing the visible gold screws on each side and remove the gold shims by hand, like undoing a button. The back of the black carrying strap is made of a light brown material that resembles tumbleweed, according to the literature, all Marshall products are vegan-friendly; only leather-like material is used. https://www.marshall.com/sg/en/product/1...
The device has a carrying strap for easy carrying. It consists of a black carrying strap(22g) and two gold irregular spacers(Less than 1g) and is attached to the body by round head screws(Less than 1g) on both sides.
Gasket height: 9mm
Gasket width: 13mm
Screw diameter: 4mm & Thread length: 9mm
Carrying strap lengths: 400mm
Carrying strap thickness: 4.5mm
Carrying strap width: 34mm
According to the information"Stockwell II’s roadworthy construction with silicone exterior also has an IPX4 water-resistance rating, so it can withstand splashes of water when the weather starts to turn."
Remove the outer rubber by hand(It may also be made of synthetic rubber)
Rubber sleeve weight: 100g
Length: 147mm
Width: 67mm
Height: 171mm
The front cover(60g) consists of a dust cloth made of black metal mesh and black translucent soft fabric with black sponge tape glued around the lining.
Use a pry bar or one screwdriver to open it along the edge. You can find 11 non-removable rivets on the back holding the logo. Use Flat Needle Nose Pliers to break off the rivets and remove the logo.
Panel length: 131mm
Panel width: 151mm
Panel thickness: 12mm
Logo length 75mm & width: 20mm
Logo spacer length: 75mm & width 17mm
Remove the screws and take off the battery cover(9g). The screws attaching the cover are two black flathead flat tip screws. Disconnect the battery(5-pin). This step does not remove the battery.
Battery cover length: 113mm
Width: 36mm
Height: 12mm
Screw diameter: 2.6mm
Thread length & Thread quantity: 4mm & 4
Head diameter:4.8mm
Remove and sort the front panel screws (×8) and the front paper cone full-range speaker screws (×4). After measuring the two screws are the same size both are round head and flat tip screws.
Screw diameter: 3mm
Thread length & Thread quantity: 9mm & 9
Head diameter:5mm
Disconnect the top control panel from the right control panel
Remove the right main control board module by hand vertically upwards, this control board is removed from the charging control board below.
Let's remember where each wire is connected.
Connect to the top control board
Bluetooth signal cable
Front and back paper cone full-range speaker connections. Note: The control panel is labeled "REAR" (2pin) and "FRONT" (3pin).
Thin Series Wooferconnect(2pin)
Cables for connecting the battery
This step allows us to take out the battery and the main control board for the stereo. And you can clearly see the internal layout.
This is the front cover that contains a small front-facing speaker and a large speaker inside.
The main body contains many things within it. This is where the battery and battery compartment are located.
The main control board is plugged vertically into the charging control board. The main control panel and top switch assembly, the battery, and each speaker connection are connected by wires.
This is the small speaker location on the back and the top switch control assembly.
Battery weight: 93g/ Length 71mm/ Width: 40mm/Thickness: 20mm
Main control board weight: 49g / length 134mm / width: 57mm
Remove the soft black gel from the paper cone fullrange speaker by hand and remove the paper cone fullrange
Remove the four screws from the thin series woofer and remove the thin series woofer.
Round head and flat tip screws(x4)/ Head diameter:5mm
Screw diameter: 3mm
The front panel is mainly divided into the housing(126g), the paper cone fullrange(93g) and the thin series woofer(159g)
Length: 143mm
Width: 166mm
Height (highest point): 45mm
Paper cone fullrange length and width: 55mm
Height: 33mm
Thin series woofer length and width: 80mm
Height: 28mm
Remove the back grill(63g) as you would the front grill.
Unscrew the four screws of the paper cone fullrange and clean the black fixing and remove the paper cone fullrange
Unscrew the four screws and remove the thin series woofer rear plate protection
The back stencil is slightly larger than the front. A mesh cover made of iron, lined with a translucent-like dust cloth and sponge tape around the edges.
Length: 156mm
Width 134mm
Height/thickness: 11mm
Paper Cone Fullrange(93g) size of the rear (2pin) Length/Width: 55mm
Height: 33mm
There is a spacer on the back of the series woofer that acts as a protector(39g), It's made of what looks like synthetic rubber, and it's encased in metal. And there is also a fragile edge spacer made of sponge.
Diagonal distance: 90mm
Diameter: 78mm
Thickness: 4mm
The screws for the speaker and gasket are the same screws, both round head, flat tip screws Head diameter:5mm
Thread length & Thread quantity: 9mm & 9 / Screw diameter: 3mm
This step disassembles the charging port control board. Start by disconnecting the 2pin wire to the top panel control board.
Then unscrew the two fixing screws and remove them, they are round heads and flat-tip screws
Screw diameter: 2mm
Thread length: 7mm
The whole of removing the charging port (9g) is divided into three parts, the main panel, the charging port rubberised case and the main body case.
Length: 53mm/Width: 18mm/Weigh: 6g
Length: 52mm/Weigh 1.5g
Width: 17mm
Height: 12mm
Length: 31mm/Weigh: 1.5g
Width: 16mm
Height: 12mm
In this step, we will take out the top part. Pull out the top whole in the direction of the arrow
This gives us a completely stripped-out enclosure and a top switch control section.
Length: 166mm
Width: 145mm
Height: 55mm
Weigh: 245g
Pull the cap off by hand or with the help of a tool.
Unscrew the four screws on the top control panel.
Four round head flat tip screws
Thread length: 7mm
Screw diameter: 2mm
Weigh: 1g
Bottom Diameter: 17mm
Height: 14mm
You can unscrew the three hexagonal nuts by hand or with the help of a tool. Unscrewing these three final screws means that the entire section will be completely separated.
After this step of disassembly it means that all of our disassembly is complete. The top section mainly consists of the switch control motherboard, iron spacer, rubber button sleeve, housing, nut to hold the switch and finally the cap.
Length of top housing long side: 127mm
Short side length: 124mm
Width: 47mm
Height: 20mm/Weight: 26g
Hexagonal nut diameter on opposite side: 10mm/Weight less than 1g
Inner ring diameter: 6mm/Thickness: 2mm
Rubber gasket Outer ring diameter: 12mm
Inner ring diameter: 7mm/Thickness: less than 1mm
Length: 21mm/Weight less than 1g
Width: 17mm
Height: 15mm
Length: 111mm/Weight: 34g
Width: 40mm
This bluetooth stereo is completely removable
The key screws in several parts of the device are of the same type and can be purchased if the screws are lost.
The battery is replaceable but requires a 5pin connector to connect.
