Introduction
The X9 requires removing the exhaust for oil changes, rear brake pad or rotor replacement, and rear tire replacement.
Pièces
Aucune pièce spécifiée.
Loosen the exhaust strap:
Use an 12mm wrench to loosen the exhaust band lock nut.
A 6mm Allen key is required to unscrew the bolt at the bottom of the band.
Once the bottom of the strap is loose, you can push it upward and slide the retaining pin that secures the top of the strap out to release it.
