Introduction
Use this guide to replace the plastic trigger buttons. The #2 trigger button has an attached internal spring.
Ce dont vous avez besoin
Remove the five 7.2 mm Phillips screws securing the rear cover to the controller.
While holding the black plastic trigger retainer with one hand, pull the #2 trigger off of its axle.
69 autres ont terminé cette réparation.
8 commentaires
Might want to add that there's a small catch/tab in the middle of the bottom of the controller that needs to be released when taking apart the covers.
This worked great, and also works on normal Sixaxis controllers. I used this to swap the broken spring from the L2 button on my DS3 for a good spring from my Sixaxis. Works like new now.
The #00 screwdriver is working better
Did you replace button 2 rod with plastic replacement part or use original rod piece when fixing button 2
Is there a way I can buy trigger retainers?
