Aller au contenu principal
Eee Pad Transformer Prime TF201 -- Opening Your Device
Conditions préalables uniquement
Ce tutoriel est uniquement destiné à être utilisé comme prérequis d'autres tutoriels. Il ne se suffit pas à lui-même.
Ce dont vous avez besoin
  1. Eee Pad Transformer Prime TF201 -- Opening Your Device, Opening Your Device: étape 1, image 1 de 1
    • Power down your device.
    • Place the small suction cup on a corner of the screen and lightly pull up to expose a seam between the screen and case.
  2. Eee Pad Transformer Prime TF201 -- Opening Your Device: étape 2, image 1 de 3 Eee Pad Transformer Prime TF201 -- Opening Your Device: étape 2, image 2 de 3 Eee Pad Transformer Prime TF201 -- Opening Your Device: étape 2, image 3 de 3
    • Insert the plastic opening tool into the seam near the corner of the device.
    • Slowly slide the tool around the perimeter of the device, gradually prying up the screen.
    • It is normal to hear snaps as the spring clips holding the screen in place are released.
    • It is also normal to hear adhesive separating, as a small amount is used to help secure the screen.
  3. Eee Pad Transformer Prime TF201 -- Opening Your Device: étape 3, image 1 de 3 Eee Pad Transformer Prime TF201 -- Opening Your Device: étape 3, image 2 de 3 Eee Pad Transformer Prime TF201 -- Opening Your Device: étape 3, image 3 de 3
    • When the screen is free of all spring clips and adhesive, slowly open the device like a clam shell with the hinge being the left hand side of the device.
    • Do not completely separate the screen from the case by more than a few inches, as they are still connected by three orange ribbon cables.
    • Safely place the device back on the table by laying the screen face down.
    • There will be some slight overlapping of the back of the case over the screen.
  4. Eee Pad Transformer Prime TF201 -- Opening Your Device: étape 4, image 1 de 2 Eee Pad Transformer Prime TF201 -- Opening Your Device: étape 4, image 2 de 2
    • Disconnect the ribbon cable by placing a plastic opening tool under the black plastic tab that is on the opposite side of the port as the ribbon cable.
    • Pry upward until the black tab moves 90 degrees, and gently pull the ribbon cable out of the port.
  5. Eee Pad Transformer Prime TF201 -- Opening Your Device: étape 5, image 1 de 1
    • Place a plastic opening tool under the white plastic tab on one of the ribbon cable ports.
    • Repeat the previous process to remove the other ribbon cable.
  6. Eee Pad Transformer Prime TF201 -- Opening Your Device: étape 6, image 1 de 1
    • Remove the battery (secured by six screws and a white wire connector) by following the removal portion of this battery replacement guide.
    • The device that we wrote this guide for did not come with a battery, so we cannot include it in our own guide steps.
    • The battery is removed during all repairs to protect against short circuits, shocks, and internal damage to the device.
Aaron Morland
Membre depuis le 10/06/16
346 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 10-1, Livingston Fall 2016 Membre de l'équipe Cal Poly, Team 10-1, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G1
2 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 5
Total : 108
