Aller au contenu principal
Epson PowerLite 77c Front Remote Sensor Replacement
Ce dont vous avez besoin
  1. Epson PowerLite 77c Front Remote Sensor Replacement, Top Panel: étape 1, image 1 de 1
    • Use a Phillips #0 screwdriver to remove the seven 5.0 mm screws on the base panel.
    • Pick up the projector with both hands, sandwiching the top and bottom of the projector together, and place it right-side-up, with the ports facing you.
    • Lift the top panel up.
    • Two connectors are holding the top panel to the motherboard; be careful not to damage them as you lift the top panel.
  2. Epson PowerLite 77c Front Remote Sensor Replacement: étape 2, image 1 de 2 Epson PowerLite 77c Front Remote Sensor Replacement: étape 2, image 2 de 2
    • Flip the locking bar of the ZIF connector vertically, then delicately remove the ribbon cable.
    • Grip the cable connector as close as possible to the plug, then pull it straight up until it releases from the motherboard.
    • Remove the top panel.
  3. Epson PowerLite 77c Front Remote Sensor Replacement, Front Remote Sensor: étape 3, image 1 de 1
    • Grip the front remote sensor's white plug and gently pull directly upwards until the plug releases.
  4. Epson PowerLite 77c Front Remote Sensor Replacement: étape 4, image 1 de 1
    • Lift the remote sensor up and out of the projector.
Julia Costantino
Membre depuis le 02/08/22
234 Réputation
2 tutoriels rédigés
Équipe
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 7
Total : 277
