Introduction
This guide demonstrates how to replace the color prisms in an Epson VS240 projector. The color prisms of the VS240 are made of glass, a potential hazard if shattered. The color prisms themselves will have to be replaced from another VS240 because the prisms are not sold individually. The color prisms are important to replace because if even a single one was damaged the image may not display as intended (i.e. incorrect colors or shapes depending on level of damage and where on the prisms the damage is located).
Power off and unplug the device before beginning.
Ce dont vous avez besoin
Using the Phillips #2 screwdriver, loosen the single captive screw on the left side of the projector.
Slide the panel off and remove it from the device.
Use a Phillips #1 screwdriver to remove two 10 mm screws from the openings on each side of the air filter, on the topside of the projector.
Using the same Phillips #1 screwdriver, remove the two 10 mm screws where the white panel was removed on the topside of the projector in Step 1.
Using a spudger or a plastic opening tool, disconnect all of the wires connected to the motherboard.
Rotate the projector 180 degrees to match orientation in images.
Using the Phillips #2 screwdriver, remove four inner 11 mm screws under the black box connected to the lens.
Use a Phillips #1 screwdriver to detach the upper plastic cover by unscrewing the six 11 mm screws.
Once the six screws are removed, lift the plastic cover and place it off to the side.
