Aller au contenu principal
Fairphone 4 Loudspeaker Replacement
Ce dont vous avez besoin
  1. Fairphone 4 Loudspeaker Replacement, Pry the back cover up: étape 1, image 1 de 2 Fairphone 4 Loudspeaker Replacement, Pry the back cover up: étape 1, image 2 de 2
    • Be sure to power off your phone before you begin.
    • Insert your thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
    • Pry the back cover up to start separating its plastic clips.
  2. Fairphone 4 Loudspeaker Replacement: étape 2, image 1 de 3 Fairphone 4 Loudspeaker Replacement: étape 2, image 2 de 3 Fairphone 4 Loudspeaker Replacement: étape 2, image 3 de 3
    • Using your thumbnail or an opening pick, slide along the right side of the phone to loosen the plastic clips.
  3. Fairphone 4 Loudspeaker Replacement: étape 3, image 1 de 3 Fairphone 4 Loudspeaker Replacement: étape 3, image 2 de 3 Fairphone 4 Loudspeaker Replacement: étape 3, image 3 de 3
    • Slide along the bottom of the phone to loosen the plastic clips.
  4. Fairphone 4 Loudspeaker Replacement: étape 4, image 1 de 3 Fairphone 4 Loudspeaker Replacement: étape 4, image 2 de 3 Fairphone 4 Loudspeaker Replacement: étape 4, image 3 de 3
    • Slide along the left side of the phone to loosen the plastic clips.
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • To reinstall the back cover press it firmly into place until you hear a snap from the plastic clips.
  5. Fairphone 4 Loudspeaker Replacement, Lever up the Battery: étape 5, image 1 de 3 Fairphone 4 Loudspeaker Replacement, Lever up the Battery: étape 5, image 2 de 3 Fairphone 4 Loudspeaker Replacement, Lever up the Battery: étape 5, image 3 de 3
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
    • Lift the battery out of its recess and remove it.
    • Remove the battery.
  6. Fairphone 4 Loudspeaker Replacement, Unscrew the loudspeaker: étape 6, image 1 de 1
    • Remove the six 4.8 mm-long Phillips screws.
  7. Fairphone 4 Loudspeaker Replacement, Slide beneath the loudspeaker: étape 7, image 1 de 2 Fairphone 4 Loudspeaker Replacement, Slide beneath the loudspeaker: étape 7, image 2 de 2
    • Use an opening pick to slide beneath the loudspeaker.
    • Slide the opening pick to the right side of the loudspeaker to release the clips that hold it in place.
  8. Fairphone 4 Loudspeaker Replacement, Lift up the loudspeaker: étape 8, image 1 de 2 Fairphone 4 Loudspeaker Replacement, Lift up the loudspeaker: étape 8, image 2 de 2
    • Slide the opening pick to the left side of the loudspeaker to release the clips that hold it in place.
    • Twist the opening pick to lift up the loudspeaker.
  9. Fairphone 4 Loudspeaker Replacement, Remove the loudspeaker: étape 9, image 1 de 2 Fairphone 4 Loudspeaker Replacement, Remove the loudspeaker: étape 9, image 2 de 2
    • Grab the loudspeaker and flip it towards the bottom to remove it.
Manuel Haeussermann
Membre depuis le 07/13/22
15 487 Réputation
71 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
16 817 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 18
30 derniers jours : 54
Total : 1,164
