Aller au contenu principal
Fan Blade Arm Replacement
Ce dont vous avez besoin
  1. Fan Blade Arm Replacement, Fan Blade Arm: étape 1, image 1 de 3 Fan Blade Arm Replacement, Fan Blade Arm: étape 1, image 2 de 3 Fan Blade Arm Replacement, Fan Blade Arm: étape 1, image 3 de 3
    • Make sure no power is flowing to the fan. Then begin by removing the metal light frame by twisting.
  2. Fan Blade Arm Replacement: étape 2, image 1 de 2 Fan Blade Arm Replacement: étape 2, image 2 de 2
    • Unscrew the finial (cover at the bottom of the glass globe). Then unscrew the hex nut and remove the rubber washer. This will allow the globe to be easily removed.
  3. Fan Blade Arm Replacement: étape 3, image 1 de 3 Fan Blade Arm Replacement: étape 3, image 2 de 3 Fan Blade Arm Replacement: étape 3, image 3 de 3
    • Remove lightbulbs to avoid damage when removing light pan. Then, remove all three fitter plate screws. This will cause the light pan to hang from the electrical wires.
  4. Fan Blade Arm Replacement: étape 4, image 1 de 2 Fan Blade Arm Replacement: étape 4, image 2 de 2
    • Disconnect single pin connectors to finish removing light fixture from fan.
  5. Fan Blade Arm Replacement: étape 5, image 1 de 2 Fan Blade Arm Replacement: étape 5, image 2 de 2
    • Remove the three screws from the fitter plate. This will allow the plate to easily be separated from the fan.
  6. Fan Blade Arm Replacement: étape 6, image 1 de 3 Fan Blade Arm Replacement: étape 6, image 2 de 3 Fan Blade Arm Replacement: étape 6, image 3 de 3
    • Remove the two screws securing the broken blade arm. Then separate the broken component from the fan.
  7. Fan Blade Arm Replacement: étape 7, image 1 de 3 Fan Blade Arm Replacement: étape 7, image 2 de 3 Fan Blade Arm Replacement: étape 7, image 3 de 3
    • Replace the broken blade arm on the fan blade. There are two components that are placed on either side of the blade and secured together with screws.
    You forgot to mention where you magically bought that replacement piece for that particular ceiling fan!!!
    Brandy Broussard - Réponse
2 autres ont terminé cette réparation.
Équipe
4 Guide Comments
Where did you bought the replacement for that specific fan I’m looking for the arm and blades with the star
Maria Franco - Réponse
I am as well and harbor breeze and Lowe's are absolutely no help!
I’m looking for the same thing CANT find it anywhere I need the arm
Lisa - Réponse
Where can I find an exact replacement.
Darrell Resler - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 20
30 derniers jours : 58
Total : 8,182
