Aller au contenu principal
Fitbit Charge 2 Touch Screen Assembly Replacement
Ce dont vous avez besoin
  1. Fitbit Charge 2 Touch Screen Assembly Replacement, Remove the watch band: étape 1, image 1 de 1
    • Before starting, take your Fitbit Charge 2 off the charger and power it down.
    • Remove the watch band on both sides.
  2. Fitbit Charge 2 Touch Screen Assembly Replacement, Heat the touch screen: étape 2, image 1 de 1
    • Heat an iOpener and apply it to the touch screen for two minutes.
    • The screen is not glued down, but the heat helps to loosen the touch screen assembly from your watch.
  3. Fitbit Charge 2 Touch Screen Assembly Replacement, Slide along the left edge: étape 3, image 1 de 3 Fitbit Charge 2 Touch Screen Assembly Replacement, Slide along the left edge: étape 3, image 2 de 3 Fitbit Charge 2 Touch Screen Assembly Replacement, Slide along the left edge: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    iSesamo Opening Tool
    $9.99
    • Insert an iSesamo into the gap between the touch screen and the watch assembly on the top left corner.
    • Slide the iSesamo along the left edge to the bottom left corner.
  4. Fitbit Charge 2 Touch Screen Assembly Replacement, Slide along the bottom edge: étape 4, image 1 de 2 Fitbit Charge 2 Touch Screen Assembly Replacement, Slide along the bottom edge: étape 4, image 2 de 2
    • Slide the iSesamo around the bottom left corner.
    • Slide it along the edge to the bottom right corner.
  5. Fitbit Charge 2 Touch Screen Assembly Replacement: étape 5, image 1 de 3 Fitbit Charge 2 Touch Screen Assembly Replacement: étape 5, image 2 de 3 Fitbit Charge 2 Touch Screen Assembly Replacement: étape 5, image 3 de 3
    • Slide the iSesamo around the bottom right corner.
    • Keep sliding it along the right edge to the top right corner.
  6. Fitbit Charge 2 Touch Screen Assembly Replacement: étape 6, image 1 de 2 Fitbit Charge 2 Touch Screen Assembly Replacement: étape 6, image 2 de 2
    • Slide the iSesamo around the top right corner.
    • Slide it along the top edge to the top left corner.
  7. Fitbit Charge 2 Touch Screen Assembly Replacement: étape 7, image 1 de 2 Fitbit Charge 2 Touch Screen Assembly Replacement: étape 7, image 2 de 2
    • Place the iSesamo under the top left corner.
    • Feel free to reattach the watch band for this and the next step for a better grip.
    • Pry up the touch screen assembly by twisting the iSesamo sideways to create a gap and unhinge the plastic clips which are holding the screen in place.
  8. Fitbit Charge 2 Touch Screen Assembly Replacement: étape 8, image 1 de 2 Fitbit Charge 2 Touch Screen Assembly Replacement: étape 8, image 2 de 2
    • Place the iSesamo under the top right corner.
    • Pry up the touch screen assembly by twisting the iSesamo sideways to create a gap.
  9. Fitbit Charge 2 Touch Screen Assembly Replacement: étape 9, image 1 de 2 Fitbit Charge 2 Touch Screen Assembly Replacement: étape 9, image 2 de 2
    • Insert a spudger into the gap on the top edge of your Fitbit Charge 2.
    • Use the spudger to pry up the touch screen assembly.
    • Do not remove the touch screen assembly all the way yet—it's still connected to the motherboard.
  10. Fitbit Charge 2 Touch Screen Assembly Replacement: étape 10, image 1 de 1
    • Carefully fold the touch screen assembly in the direction of the bottom edge.
  11. Fitbit Charge 2 Touch Screen Assembly Replacement, Remove the protecting sticker: étape 11, image 1 de 2 Fitbit Charge 2 Touch Screen Assembly Replacement, Remove the protecting sticker: étape 11, image 2 de 2
    • Use a pair of blunt nosed tweezers to remove the black sticker which covering the touch screen connector.
  12. Fitbit Charge 2 Touch Screen Assembly Replacement, Open the ZIF connector: étape 12, image 1 de 2 Fitbit Charge 2 Touch Screen Assembly Replacement, Open the ZIF connector: étape 12, image 2 de 2
    • Use the pointed end of a spudger to open the ZIF connector by pushing up the black flap.
  13. Fitbit Charge 2 Touch Screen Assembly Replacement, Remove the touch screen assembly: étape 13, image 1 de 3 Fitbit Charge 2 Touch Screen Assembly Replacement, Remove the touch screen assembly: étape 13, image 2 de 3 Fitbit Charge 2 Touch Screen Assembly Replacement, Remove the touch screen assembly: étape 13, image 3 de 3
    • Pull the touch screen flex cable straight out its socket.
    • Remove the touch screen assembly.
If possible, turn on your device and test your repair before reassemble.
Opening didn’t go as planned? Ask our Answers community for help.
12 autres ont terminé cette réparation.
Adriana Zwink
Membre depuis le 12/18/19
62 043 Réputation
167 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
123 membres
23 638 tutoriels rédigés
1 commentaire de tutoriel
This is great
Mohsen - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 20
30 derniers jours : 88
Total : 16,568
