Introduction
If your Flydigi Apex 5 controller fails to turn on or loses power sooner than expected, the cause may be a failing battery. Batteries fail overtime as they are repeatedly charged and discharged from use. Follow this guide to replace the battery.
Before starting, consult the Flydigi Apex 5 Not Charging troubleshooting page to confirm that the battery is your controller's issue.
Warning: Lithium-Ion batteries can be a fire hazard. If the controller battery appears swollen, follow iFixit's guide on What to do with a swollen battery.
Ce dont vous avez besoin
Orient the controller so that its back is facing you.
Apply firm downward pressure to remove both the M3 and M4 back paddles.
