Introduction
We will start by removing the wheel and removing any debris that may be obstructing motion, and then reattach the wheel to the axle of the Free Wheelchair Mission GEN 1.
Familiarize yourself with the tools required for this guide by reading through the Free Wheelchair Mission Tools Maintenance Guide.
Ce dont vous avez besoin
Use the socket head of the 19mm wrench to unscrew the nut that connects the castor wheel’s fork to the steel frame.
Remove the wheel from the small steel frame.
Hold the bolt that connects the wheel to the fork with pliers.
Use the socket head of the 10 mm wrench in your other hand to remove the nut on the other end of the bolt.
Flip wheel over and remove the bolt.
Remove the castor wheel.
Check for and remove any debris from the wheel or wheel axel that may be obstructing motion.
