Aller au contenu principal
Frigidaire Side-By-Side Refrigerator Condenser Inspection and Cleaning
Ce dont vous avez besoin
  1. Frigidaire Side-By-Side Refrigerator Condenser Inspection and Cleaning, Unplug your refrigerator: étape 1, image 1 de 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. Frigidaire Side-By-Side Refrigerator Condenser Inspection and Cleaning, Unfasten the rear cover: étape 2, image 1 de 1
    • Use a 1/4" nut driver to remove the four screws securing the rear cover to the refrigerator.
  3. Frigidaire Side-By-Side Refrigerator Condenser Inspection and Cleaning, Lift up the rear cover: étape 3, image 1 de 3 Frigidaire Side-By-Side Refrigerator Condenser Inspection and Cleaning, Lift up the rear cover: étape 3, image 2 de 3 Frigidaire Side-By-Side Refrigerator Condenser Inspection and Cleaning, Lift up the rear cover: étape 3, image 3 de 3
    • Lift the rear cover until it is free of the tabs.
    • If your water supply line is in use, turn the supply valve off, and disconnect it at the connection on the refrigerator.
    • If the water supply hose is not used, pass it through the hole in the cover.
  4. Frigidaire Side-By-Side Refrigerator Condenser Inspection and Cleaning, Remove the cover: étape 4, image 1 de 1
    • Remove the cover and set it aside.
  5. Frigidaire Side-By-Side Refrigerator Condenser Inspection and Cleaning, Clean and inspect the condenser.: étape 5, image 1 de 2 Frigidaire Side-By-Side Refrigerator Condenser Inspection and Cleaning, Clean and inspect the condenser.: étape 5, image 2 de 2
    • Use a soft brush to clean the condenser coils.
    • A vacuum cleaner with a hose can also be used alone or in combination with the brush for cleaning.
    • Look for oily spots on the condenser coils, often dust will stick in those places. This can be a sign of a refrigerant leak.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
Membre depuis le 06/30/22
38 497 Réputation
261 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
123 membres
23 623 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 21
30 derniers jours : 115
Total : 1,088
